Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Apr 14, 2022 at 11:01 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    FYI - While working on @81Trekker 's fenders I figured out an easy way to put an inner lip back onto a cut fender. Use a flexible template board like Ramboard cardboard ( would need a release agent ) or the thin plastic template board stock which will release and leave a perfect surface. Cut it into 2" strips 4' long and tape it to the lip all the way around then lay up chopped mat from the back of the fender up the lip. 8 layers of mat and you'll have a return edge as thick as the fender itself. Maybe Harry can post a pic of how I have his front fenders jigged up currently.
    Camazon and Murphinator like this.
  2. Apr 14, 2022 at 11:20 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    It's funny you mention that. I was actually playing with a flexible ruler the other day and had it taped up to the edge thinking it would work to form a new one. I don't mind not having the lip there so I'm a little undecided on what I will do. If I leave it bare I was just going to put some U-channel around so rocks don't smash it apart.
  3. Apr 14, 2022 at 11:39 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    A clean 1/4" return just makes it look really " pro" ...and adds some rigidity as well.
  4. Apr 14, 2022 at 3:49 PM
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    Yeah I just took it to a shop around here that does a lot of custom jeeps. I agree with Harry though. I mean weights have been proven to work well so why do something different. Beads just seem to hit and miss. Didn’t really want to work for my situation and I was tired of messing with it.
  5. Apr 14, 2022 at 5:07 PM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    I have 37x12.5x17 Geolanders on some Icon Rebound Pro wheels, Icon's version of a beadlock, DOT approved.
    105 lbs wheel and tire.
    4 of the 5 tires balanced with 1.5 oz or less :thumbsup:
    Here's how they balanced out, 5 tires in all.
    .75oz
    1oz
    1.25oz
    1.5oz
    2.75oz
  6. Apr 14, 2022 at 6:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    First time I’ve seen those in the wild. It’s a pretty clever design and seems like it would be pretty lightweight compared to a traditional beadlock.
  7. Apr 14, 2022 at 10:44 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    That technology is interesting. I’m a bit iffy on the looks of that wheel, but I’m spoiled.
    TacoEspecial and BassAckwards like this.
  8. Apr 15, 2022 at 7:00 AM
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    Hey @81Trekker, what’s the best way to take these 934s apart. And what’s the best way to pack them full of grease. I see this tool but it seems kinda silly to need it. And I ordered the boots and Jesse sent hardware. Thanks!
  9. Apr 15, 2022 at 7:11 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Just unbolt them from the flange. I use the swepco grease in the caulk tube and squirt it in with the caulk gun. Mess free, quick and easy
    Slashaar and NcTaco27[QUOTED] like this.
  10. Apr 15, 2022 at 7:15 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    I have the same tire in 35’s and really like them. Isn’t the red dot supposed to go on the valve stem or did I just understand wrong?
    TacoEspecial[QUOTED] likes this.
  11. Apr 15, 2022 at 7:20 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    With how much time you put into the rear of the frame and trying to stiffen the frame is there a reason you didn’t just do a cage? Just seems like the time you put into it you probably could of just done a cage.
  12. Apr 15, 2022 at 8:04 AM
    906taco
    Cory
    08 Taco
    I’ll be putting just as much focus in the center of the truck too. Next year it will be caged. Basically laying a solid foundation for a cage. IMO if you land tube on top of c-channel you’re still going to get some amount of flex. You won’t often see a cage landing on a c-channel frame that hasn’t been boxed.
    NcTaco27 and lferrara[QUOTED] like this.
  13. Apr 15, 2022 at 9:20 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Why land on top?
  14. Apr 15, 2022 at 9:32 AM
    906taco
    Cory
    08 Taco
    Is there something wrong with boxing the frame in and adding extra bracing along with a cage? Because in my mind it’s the best way of doing it. It’s what I’ve done many times over on cars to stiffen the chassis as much as possible. And it definitely does help.
  15. Apr 15, 2022 at 9:40 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    You completely missed the point. Where else where you advise landing the tube on a C-notched frame?
  16. Apr 15, 2022 at 9:50 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I’ve seen people intersect the top plate on the c and have it land on the bottom c. Weld at both locations and then plate once done. Adds some complexity when designing and measuring but helps spread the load.
    TacoEspecial likes this.
  17. Apr 15, 2022 at 9:58 AM
    906taco
    Cory
    08 Taco
    Also a solid option. The route I’m going is I’ll be doing internal gusseting on the frame where the A, B and C pillar tubes will land.
  18. Apr 15, 2022 at 10:13 AM
    01 dhrracer
    Still Shopping
    This is what I was getting at. But if the tube intersects the top and lands on the bottom does plating really add a benefit. But will take it a step further. Add cross tube structure. Use the frame essentially as a fixture for the tube structure.
  19. Apr 15, 2022 at 10:18 AM
    906taco
    Cory
    08 Taco
    Of course plating adds a benefit. Especially on a frame that is comparable to a noodle. My plan eventually involves a fuel cell to open the door for even more bracing under the body. Necessary? I’m not sure. But I certainly don’t see the harm in making your chassis as stout as possible from every direction. And a cage alone doesn’t do that unless you lace the shit out of it and lose room in the passenger compartment.
  20. Apr 15, 2022 at 10:26 AM
    01 dhrracer
    Still Shopping
    I am not saying plating would not add something but with a solid truss/triangled tube design would it be a measurable improvement?
