Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. May 6, 2022 at 7:38 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Glad they were harnessed and had helmets for sure. His dad was riding along and he’s late 60’s. Lucky the two of them were just a little sore the next few days
    Slashaar[QUOTED] likes this.
  2. May 7, 2022 at 8:56 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    I was thinking. Get a cheap CV axle from the parts store. Cut off the axle and just have spare inner/outer in case of a axle breakage. But, with the 934, I kinda doubt it.
    Thoughts?
    Slashaar likes this.
  3. May 8, 2022 at 1:09 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    I have 934s and I carry just the gutted stubs from some old napas to plug the holes on the off chance one breaks. I know the inner can be unbolted, but why bother
    Slashaar and ovrlndkull like this.
  4. May 8, 2022 at 3:01 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I've already got one like that for that reason and will keep it just in case.
  5. May 8, 2022 at 8:01 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Very well, then I'll get a el cheapo axle and cut it, clean it. Carry the stubs.
  6. May 8, 2022 at 8:36 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    If you have 934’s you can unbolt the CV in under 1 minute. If you broke an axle you’re gonna have to unbolt the CV anyways to replace the axle so might as well just do it on the trail and avoid carrying a spare, your trucks are heavy enough! With all of that said you are not gonna break a 300m axle so my above comment is basically worthless :)
    01 dhrracer likes this.
  7. May 8, 2022 at 8:58 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Why does the CV have to be unbolted to be removed? You’re talking about the Allen bolts right?
  8. May 8, 2022 at 9:01 AM
    81Trekker
    La Jolla SD
    Correct, the 934 is bolted to the inner stub shaft. If you pull the 6 Allen bolts the entire CV comes off and you are left with the 934 stub shaft in the diff. It’s probably easier to unbolt the CV then to remove the stub shaft. My point is why carry a spare stub shaft to use as a plug when the 934 stub shaft already accomplishes that
  9. May 8, 2022 at 9:01 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Less troublesome and easier than dropping skids and fighting knocking the inner out. Plus it'll leave the stub in. You don't have to but it's quicker.
    Dayman Karate[QUOTED] likes this.
  10. May 8, 2022 at 9:08 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That makes sense. Would you be left with a bunch of grease slinging around? I honestly have no idea what they look like broken down haha. Anyone running them with 40’s that you know of?
  11. May 8, 2022 at 9:10 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Yours came out of the diff easier than the hub, why is that? :rofl::rofl:
  12. May 8, 2022 at 9:17 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Secret.
  13. May 8, 2022 at 9:18 AM
    81Trekker
    La Jolla SD
    The grease is packed into the CV and boot, the 934 flange face is essential flat so there will be a small amount of grease that can be wiped off with a couple napkins.
    There are quite a few class one and Dakar trucks running 934’s with 300m axles so you should be ok doing it on a Tacoma especially since you are down about 600HP :)
    Honestly the Tacoma diff doesn’t stand a chance with 40’s unless maybe you have the worlds slowest taco... insert eye roll here
  14. May 8, 2022 at 9:18 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes you're essentially opening them up and you'll see the balls and cage, there will be grease you can wipe it up it won't be too bad.
  15. May 8, 2022 at 9:23 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I'm thinking more of the outer. If that breaks. Since its kinda needed to hold the wheel on.
  16. May 8, 2022 at 9:24 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Nah another company that shall not be named beat us all to having the slowest Tacoma :rofl::rofl:
    also couple of napkins my ass. I have cv grease on everything in my life after taking two apart. I should have done that shit with a hazmat suit.
  17. May 8, 2022 at 9:27 AM
    81Trekker
    La Jolla SD
    The wheel is held on by the unit bearing, not the birfield. If you remove the axle it’s no different than a 2wd Tacoma.
  18. May 8, 2022 at 9:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s not accurate, the outer stub holds the wheel bearing together. Had a buddy not know this, drove without a cv after breaking one and his wheel almost fell off shortly after.
    Buttskevin21 and desertjunkie760 like this.
  19. May 8, 2022 at 9:33 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    yea, not the 4wd.
  20. May 8, 2022 at 9:33 AM
    81Trekker
    La Jolla SD
    I understand this and I guess it got lost in translation, my point was you don’t need the birfield to be intact to drive the truck. You can explode the birfield and as long as the stub is bolted in to retain the bearings you can drive home.
    tacotunner06 and ovrlndkull like this.
