Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. May 25, 2022 at 2:38 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I'd be first in line for a core support built similarly to the inner fenders. I too don't really dig the tube structure and would like something a little beefier than stock. I figured I'd get one of the better quality cores then add some additional strengthening where mine is failing. FWIW mine is failing in many places not just the DS.
  2. May 25, 2022 at 9:06 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    So, was able to get into a little bit of actual go faster stuff.
    Even manually going full bump and checking for clearance and such with a jack. Still found some rubbing that should be fixed with the JD Inners. So, I wasnt able to compress my rubber bumps enough under static weight of the truck to clearance.
    Then on the bigger whoops. The rear even with 12" shocks and spring over. Yea, found its limit. Granted I'm missing weight on the back and the one Radflo is leaking. Staying spring over for the foreseeable future for now. Just changing to bypasses to hopefully make the rear work a bit better.
    Not trying to make my truck keep up with the super go fast trucks. But be a bit better and work decent when bombing down 2 tracks through AZ and UT.
    llibrm likes this.
  3. May 25, 2022 at 10:20 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    details on the rear setup?
  4. May 25, 2022 at 10:30 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Just a simple Archive kit with 12" 2.5 Radlfo and All Dog Performance leafs which are a style of RXT. Multi leaf that you can vary for loads. I have all leaves in because of the old rack and rtt.
    GFC goes on in a few weeks.
    RoaminRoman and Supra4x4 like this.
  5. May 25, 2022 at 10:32 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    FJwVTiCvV_oILsfXUaGyPj5b4vYN27QXWXIpHFeo_2ba629d0266dddf097d41ad12095e14a5454539e.jpg
    jp_flynavy and Torspd like this.
  6. May 25, 2022 at 10:33 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Am I tripping or is the shaft black and not chromed?
    Slashaar likes this.
  7. May 25, 2022 at 10:41 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    That's what she...wait.
  8. May 25, 2022 at 10:44 PM
    desertjunkie760
    Shane
    Check My Sig.
    :rimshot:
    Slashaar[QUOTED] likes this.
  9. May 26, 2022 at 3:04 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Have fun making that rear work better when all you have is 4” uptravel. Trust me. I tried and tried. You just can’t work with 4”. I got mine fairly decent. But no matter what the go fast stuff just wasn’t very good. Take the money you’re going to spend on bypasses and put it towards SUA.
  10. May 26, 2022 at 5:25 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    That's what....nevermind
  11. May 26, 2022 at 5:35 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Mr. Harry, how far forward can you go on the pivots with the 2.25” kit? I’ll be doing hydro and could place it wherever need be if tie rods are the determining factor. Anything to help clear 40’s would be nice.
    T.Barn likes this.
  12. May 26, 2022 at 5:51 AM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    :eek:
  13. May 26, 2022 at 6:34 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    You be tripping. It’s chromed.
  14. May 26, 2022 at 6:40 AM
    906taco
    Cory
    08 Taco
    If you're doing full hydro you can push it forward all the way. Zero reason you couldn't. But you will be into the headlights 100% with 40's
  15. May 26, 2022 at 7:02 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I just to not try to go into big go fast stuff. And remember I’m just trying to add travel and make it more fun for an overall experience.
  16. May 26, 2022 at 7:08 AM
    906taco
    Cory
    08 Taco
    Then you want SUA…..
  17. May 26, 2022 at 7:17 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
  18. May 26, 2022 at 7:39 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Maybe. Down the road.
    Work being a bitch
    Plus have plenty other stuff to get done way before that’s looked at.
  19. May 26, 2022 at 7:47 AM
    81Trekker
    La Jolla SD
    I’d be very careful with a full hydro system and 40’s. You are essentially bolting a hydraulic tubing bender to the front of your truck. The correct way to do it is to have the double ended ram built with internal stops otherwise you will destroy the spindles, especially the steering arms. You will also need a TC pump and big cooler as the fluid will get hot quick. Call me if you want help setting the truck up with the correct parts let me know and we can work with Howe... fair warning it won’t be cheap but it will be done right
    Anderson5290, Torspd, Spintly and 3 others like this.
  20. May 26, 2022 at 7:51 AM
    906taco
    Cory
    08 Taco
    Biggest tip I’ve got to help it for now is get aggressive with valving. It won’t ride the best all the time but it will do better in rough stuff. Also get the softest bumps you can find.
