Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jul 5, 2022 at 5:56 PM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I mean mines still really close to stock
  2. Jul 5, 2022 at 6:09 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    well…you do still have unmolested OE Toyota doors and….nope that’s it
  3. Jul 5, 2022 at 6:11 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  4. Jul 6, 2022 at 4:54 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Anybody have a stock frame to ground measurement for 2nd/3rd gens? For whatever reason people like to measure hub to fender or ground to fender which is not an accurate way of measuring in my opinion.
  5. Jul 6, 2022 at 4:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you trying to measure lift height?
  6. Jul 6, 2022 at 5:00 AM
    906taco
    Cory
    08 Taco
    Yes. I've had like 50 people locally ask. I think it's close to stock as far as suspension goes. Obviously tires added lift though, but that's an easy number to rough in.
  7. Jul 6, 2022 at 5:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For the rear, top of axle tube to bottom of frame rail is 8.25" stock so that's an easy and accurate way to measure the rear. Front, no idea, I just guesstimate personally. I'll be curious to see what you figure out, maybe make a trip to a dealership.
  8. Jul 6, 2022 at 5:05 AM
    906taco
    Cory
    08 Taco
    I might actually do that. I'm not sure why nobody uses the frame as a measuring point. Because that seems to be the most accurate way to measure from truck to truck.
  9. Jul 6, 2022 at 5:15 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Probably because tires are taken into account when measuring there, and tire sizes vary so much based on how worn they are and discrepancies between different manufacturers. When people are boasting their lift down to the 1/4" tolerance, that wouldn't be super accurate. Really none of this is that accurate though, minus the axle to frame measurement.
    Out of curiosity I just took some measurements on my truck. 18.75 passenger side and 17.25 drivers side measuring right behind the cab mount. Comparing to points on the body only brings a 1/2" delta. So, who really knows.
  10. Jul 6, 2022 at 5:19 AM
    906taco
    Cory
    08 Taco
    Personally, when I think "lift" I think raising the frame. Anything that raises the frame "lifts" the truck. Tires included.
  11. Jul 6, 2022 at 5:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Of course this is all subjective but I would say you're in the minority. Any one of those 50 people asking about lift probably aren't thinking about your frame height, they're wondering if they can shove a 3" lift spacer in there to get that same #stance and clear 37s.
  12. Jul 6, 2022 at 6:02 AM
    906taco
    Cory
    08 Taco
    Im genuinely curious about it myself. I know getting in and out of the truck it seems lower than the old setup yet it seems massive standing in front of it. But the hood and fenders are also up like 2.5" over the second gen stuff. The stance and height it is right now is pretty killer. Not sure what it is about a low ride height and big meats, but it makes me pitch a tent.
  13. Jul 6, 2022 at 6:03 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Have you measured your frame height yet?
  14. Jul 6, 2022 at 6:05 AM
    906taco
    Cory
    08 Taco
    Yes. I have 19.125" under the front cab mount. Stock size tire would put it around 15.5 or so.
  15. Jul 6, 2022 at 7:02 AM
    99GC8
    99GC8 Well-Known Member
    Dwight
    Fort Collins
    2015 Taco supreme
    Pretty sure that most 2.5- 3” lifts and 285s put the frame around 18.5”
    Been awhile since I’ve measured.
  16. Jul 6, 2022 at 9:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @81Trekker @Airdog on the back of the oem power steering pump there's a ground wire bolted to this. My assumption is that this is for the oem oil pressure switch, and neither is needed anymore so I can leave both disconnected.
  17. Jul 6, 2022 at 9:42 AM
    81Trekker
    La Jolla SD
    Reattach the ground wire and you leave the plug disconnected
  18. Jul 6, 2022 at 9:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks. I was surprised to see it as there's not even mention of it in the FSM.
  19. Jul 6, 2022 at 9:49 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    According to @RonRon23 the wire you leave disconnected just ups the idle to give you more pressure at low rpm on the stock pump. Just so you know what it is you are leaving off.
  20. Jul 6, 2022 at 10:02 AM
    906taco
    Cory
    08 Taco
    Only bumps the idle with the stock pump. Not the TC
