Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Sep 10, 2022 at 7:09 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I’ve followed in this thread for a while. And heard numerous people talk about shortening a bump. Which I understand why and everything. But I’d be lying if I said I can feel my fronts or rears engage. I can hear them slap occasionally but that’s about it. I’d be really curious to know what the internal pressure increase is per inch of compression.
  2. Sep 10, 2022 at 7:18 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I would constantly hear my fronts engaging. After shortening them to 1 inch not so much anymore. My rears I shortened to 2 inches because at 4 inches you are putting almost 25% of your travel in the bump…not ideal IMO. My favorite kind of wheeling is hitting whoops at speed and with that you are spending a lot of time in the bump stops. So I optimized it to my liking.
    desertjunkie760 likes this.
  3. Sep 10, 2022 at 7:19 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    That’s probably because you’re only running 30 psi in the rear. Lol
    With you having a bypass shock, you can rely on the bump zone of the bypass and not solely on the bump stop itself. That along with low psi is probably why you can’t feel the engagement.
    I can’t feel my fronts as much as the rears due to the leverage from the motion ratio but I can tell occasionally depending on how hard of a hit.
    Pressure buildup would be directly related to the nitrogen pressure you’re running. Standard hydro bumps are an air shock at the end of the day.
    Airdog likes this.
  4. Sep 10, 2022 at 7:32 PM
    906taco
    Cory
    08 Taco
    I
    I guess at the end of the day, it’s probably different terrain styles. Where I’m at I have very high shaft speed terrain. Lots of wicked chop. I’ve been learning to use them to my advantage. I don’t use every last bit of travel I have front or rear. It’s very close. But I have yet to fully compress a bump. My god the ride on this shit….
    RonRon23 and Airdog like this.
  5. Sep 10, 2022 at 9:16 PM
    desertjunkie760
    Shane
    Check My Sig.
    I don’t associate the zoning of the shocks with terrain or even driving style but all that matters is if you’re happy with your setup. Obviously different expectations for different people and applications.
    Im curious to know how far you are from engaging the bump at ride height in the front. What springs did you end up going with?
  6. Sep 10, 2022 at 10:52 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    If the bumps are bled properly, then there should be roughly as much nitrogen volume as there is exposed shaft, plus a little. So if you say on a 2" bump there is roughly 4cubic inches of volume, with 1cubic inch of nitrogen volume at full compression, set at 100psi, compressed 1" would be 200psi and fully compressed would be 400 psi
    It's called Boyles law, and if you have the actual volumes you can pretty easily figure it out
  7. Sep 10, 2022 at 10:55 PM
    WormSquirts
    Braeden
    BC
  8. Sep 11, 2022 at 6:36 AM
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    So apparantly part number 44250-04040 (Rack assembly) is on natonal back order with no date of stock from what I am getting. Edit - I am an idiot too. 44250-04021 replaces 44250-04020 which is the 2wd version. 44250-04040 is the 4wd version from what I am understanding.
    Also never take your truck to a unknown/not already trusted alignement shop. They completely destroyed my cam bolts. Idiots.
    Slashaar likes this.
  9. Sep 11, 2022 at 7:15 AM
    906taco
    Cory
    08 Taco
    I would have to look in my notes. I honestly don’t remember. I’m on 600’s up front. All I know is I have it setup to the point I cannot feel my bumps engage front or rear. I’m averaging right around 1/2-3/4” of bump left on all 4 corners. My big advantage is my terrain typically isn’t bigger than my travel anymore. I don’t know as though better is achievable in my area.
    I have pursued shock tuning quite heavily to get it to this point as well. I’m not sure how much everybody else is diving in to change valving, bleed etc. But I’ve had all 4 shocks off probably 10x now. My entire goal was a smooth transition through the entire range of travel. I certainly did not have that with the base tune that came with these shocks. It was simply too stout for a while and at that point my bumps did feel like hitting a wall.
  10. Sep 11, 2022 at 7:30 AM
    906taco
    Cory
    08 Taco
    I guess that’s kind of my point. Wouldn’t you be better tuning the shock to eliminate some of the harshness from the bumps? If pressure is doubled half way through the travel like I assume it is you’re gradually ramping up the bump stop force vs whacking a good bit of pressure the second it touches the bumps. I’ve never tuned for big whoopy stuff but I assume you’re bottoming bumps all day long. Mine is basically tuned for straight up chop/sharp edge type stuff. Likely just different worlds as far as why I’m not fully grasping your end.
  11. Sep 11, 2022 at 7:40 AM
    desertjunkie760
    Shane
    Check My Sig.
    :worthless:
    Replace “pics” with “video”.
  12. Sep 11, 2022 at 7:42 AM
    906taco
    Cory
    08 Taco
    I have some boring ones on my IG
    906Taco.
    going out this afternoon I’ll try to take some better ones…
  13. Sep 11, 2022 at 8:15 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Heading out with @Sixthelement later this morning hopefully for a tuning session. Pulled a leaf Friday and truck seems to be feeling a lot more balanced again. Will try to get videos for later.
  14. Sep 11, 2022 at 9:07 AM
    desertjunkie760
    Shane
    Check My Sig.
    what leaf pack is he running? Still SOA yeah?
  15. Sep 11, 2022 at 9:13 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah he’s still soa and running some all dogs leaf’s I think. I was talking about my truck though. Been fighting the weight loss in the rear with tuning so pulled one of mine. He’s all loaded up for a trip next week he said so will probably ride along with me and help film and what not
  16. Sep 11, 2022 at 9:20 AM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I have an 07 V8 4runner and have TC upper control arms, Whiteline LCA bushings, Poly bushings in the rack, new-ish TREs, rag joint removed in the steering shaft, as much caster as I can get out of it and still get a lot of feedback into the steering wheel going over bumps. Guessing it could be the 215k mile steering pump since I've eliminated nearly every other factor in sloppy steering?
  17. Sep 11, 2022 at 9:25 AM
    906taco
    Cory
    08 Taco
    The TC pump helps substantially. I still had some feedback with the TC, slide rack and mid travel. For whatever reason going long travel took the rest of the feedback away.
  18. Sep 11, 2022 at 9:26 AM
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I wonder if the V8 runners have a TC style pump from the factory, would be nice to throw a Howe pump in there.
  19. Sep 11, 2022 at 9:28 AM
    906taco
    Cory
    08 Taco
    It’s worth a look. Lots of T4R stuff is shared with Tacoma as well. But yes, your pump is probably tired.
  20. Sep 11, 2022 at 9:38 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Sounds like you dislike the lack of steering feedback. Are you instead talking about bump steer? Steering feed back is important and why steering alignments are very important because if any of that is off, a driver can sense and feel it definitely. I haven't driven my FJ yet but part of the reason we resort to solid mounts, joints and bushings is for the feedback.
