Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Nov 16, 2022 at 5:37 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    those wires are easily damaged without any outward appearance of damage. Id take the plug off at the sensor and up above the coil bucket and ohm ot the wires between those 2 plugs to see if you have continuity. I'd be willing to bet you its that run of wire thats bad. Next run of wire goes straight to the ABS ECU.
    Slashaar and EatSleepTacos like this.
  2. Nov 16, 2022 at 5:38 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    SNIPED!!..talk about being on the same page
  3. Nov 16, 2022 at 5:42 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ve seen it happen too many damn times. $10 says that’s the case.
    Slashaar and Airdog[QUOTED] like this.
  4. Nov 16, 2022 at 5:51 PM
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    It never ends... Okay I'll grab my meter and check that in a minute.
    Okay so wires are good. I am getting continuity through the Leeds in the sensor though. So the sensors probably bad. I don't get a reading through the passenger side one so that has to be it.
    Slashaar likes this.
  5. Nov 16, 2022 at 6:13 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    swap sensors side to side to see if the problem moves.
    TireFire likes this.
  6. Nov 16, 2022 at 6:13 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    prob not it but just for shits n giggles pull the sensor and clean it really good and try again
  7. Nov 16, 2022 at 7:02 PM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Thanks guys. I will keep messing with it. Worried it was something in the harness but from the plug at the sensor I am not getting any continuity so hopefully everything's fine. Hopefully it's the sensor but I'll let you know when I figure it out. That's a good idea @Airdog. I will try that and just double check they are cleaned really well.
  8. Nov 16, 2022 at 7:51 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I thought the sensors were directional. Probably could go front to back though
  9. Nov 16, 2022 at 8:15 PM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    I swapped the rear driver with front driver and it stays on the front left. So it's something else..
  10. Nov 16, 2022 at 8:18 PM
    DocME
    California
    '07 FJ Cruiser
    Did you drive it or just start it? It needs a short while to set the code or clear it. Needs to see movement.
    Also, I replaced two sets of cables for those sensors. Agree they are very delicate.
  11. Nov 16, 2022 at 8:23 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    They are aren't they? didn't we have a conversation about this because of the dirt designs kit....can't remember anymore...lol
    also I finally fixed all my christmas tree lights on my cluster from ripping out half the systems in my truck....
    Slashaar, T.Barn, CGoss and 1 other person like this.
  12. Nov 16, 2022 at 8:43 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Your tire light is on
    tacotunner06[QUOTED] likes this.
  13. Nov 16, 2022 at 8:55 PM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    I don't think you have too. I actually forgot to plug in the rear one when I switched them. Then both came on and after I realized it I plugged it in. Cleared the codes and restarted the car. Then just the front one came on again. You'd think for a short or open circuit the computer would be able to tell right away. But idk.
    Maybe I'll just replace that cable and see if it fixes it. I'm not getting any continuity between the wires so one of them must of just got tweaked or something. Didn't realize how delicate they are.
  14. Nov 16, 2022 at 8:57 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    On mine after I sliced a wire/fixed it, it took ~100ft of driving before it turned off
  15. Nov 16, 2022 at 9:07 PM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Strange. Wonder why mine went away immediately after clearing and restarting on the one that was unplugged. I will try to drive it around a little and see if it fixes it.
    After looking into it more they do say you have to drive at 25mph for 60 seconds.
  16. Nov 17, 2022 at 2:37 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can cut off each end of the harness and solder in your own wire. I’ve done that before with 14 gauge because it’s all I had on hand and the repair is still holding.
    I’ve also never had to drive to get the fault to clear, not with a broken wire anyways.
  17. Nov 17, 2022 at 3:06 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    What is ABS? Sounds troublesome.
  18. Nov 17, 2022 at 6:19 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Well. Thanks guys. You were right. It's the harness. Getting 11 volts at the connector before the harness and nothing at the sensor.
    EatSleepTacos[QUOTED] and Airdog like this.
  19. Nov 17, 2022 at 1:42 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I've continuity tested a bunch of those harnesses, and it's never helped haha. The wire is usually still connected enough to show continuity, but not enough to actually work. The ABS system is pretty sensitive. It's almost always broken at the spot where it's in the bracket on the UCA where it turns to go down the spindle, so check there first. A bit of solder and some heat shrink and you're good to go.
    I have also needed to drive a bit for the light to go off in the past as well.
    Airdog, DocME and lferrara[QUOTED] like this.
  20. Nov 17, 2022 at 6:15 PM
    906taco
    Cory
    08 Taco
    Am I doing this right? I’d have to be getting 8-10k to do a cage in a taco. Been a tech for quite some time now and I’m not sure I’ve ever encountered a dash quite on this level.
