Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Dec 12, 2022 at 7:47 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    It was around the time you posted that that I noticed it. Of course getting into weather now so quickly getting harder to work on things. After the trip last weekend it is on a high priority to figure out before KOH. Hopping a rear rear down finds nothing and front tear down has heims and this steering issue to find.
  2. Dec 13, 2022 at 3:51 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    It’s probably the factory rack. Mine is the same way. I have a solid inch of play at the wheel. Going reman this time considering the OE racks are now like 800$. Either way, I’m not breaking them anymore. Just wearing them out. I’ll take it as a win.
  3. Dec 13, 2022 at 5:32 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    This is my third rack. It’s a reman from the rack doctor. Swapped this one in when I did the slide rack. It’s just weird that it seems to be only when the wheel is centered. Need to look into it some more obviously
  4. Dec 13, 2022 at 6:04 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I've heard nothing but bad things about rack doctor. Maybe they've gotten better or are just better at doing 2nd gen rack remans?
  5. Dec 13, 2022 at 6:41 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Last one held up fine for the abuse I put it through. Was starting to weep after about 3 years. Replaced it because I was doing the slide rack and wanted everything fresh.
  6. Dec 13, 2022 at 7:19 AM
    906taco
    Cory
    08 Taco
    That’s how mine is too. I’ll shoot you a video on IG of how mine is since it’s all exposed
  7. Dec 13, 2022 at 7:40 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Would going up in tube thickness help?
  8. Dec 13, 2022 at 7:54 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I just emailed you a vid that’s scary to watch... also a huge reason why the banjo bolt can contact the shock mount at full lock... @EatSleepTacos sending it to you too
  9. Dec 13, 2022 at 8:01 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dang dude, that's with the slide rack too. Impressive.
  10. Dec 13, 2022 at 8:05 AM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    What wheels are those?
  11. Dec 13, 2022 at 8:14 AM
    81Trekker
    La Jolla SD
    The factory rack bushings are hollow on either side so the rack can slide back and forth. Add in a 1500psi TC pump and it only makes the problem way worse
  12. Dec 13, 2022 at 8:15 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    SoonToBeOn39s[QUOTED] likes this.
  13. Dec 13, 2022 at 8:23 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah that’s pretty bad. So about those nylon bushings? When can we get a set sent out lol
  14. Dec 13, 2022 at 8:27 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    @81Trekker when you caged the silver truck, did you move to solid bushings on the cab mount? Is there any movement? I was looking at @WormSquirts pictures and thinking about the stresses on the sheet metal around the passthroughs since the cage is attached to the frame and the cab is on mounts.
    Actually now that I think about it more the cab is welded to the frame with gussets isn't it? Carry on.
    @snowsk8air2 Are Milestars good on road too? I hear they are definitely a loud road tire. I guess you might be biased though :rofl:
  15. Dec 13, 2022 at 8:29 AM
    81Trekker
    La Jolla SD
    The entire cab is welded to the cage in a million places
  16. Dec 13, 2022 at 8:30 AM
    81Trekker
    La Jolla SD
    Next week they will be on the website
    Sixthelement, a2lowvw and Murphinator like this.
  17. Dec 13, 2022 at 8:33 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    What he said. The cab is welded in a bunch of places to the cage.
    As for road noise, they are a mud terrain. I feel they aren’t much louder than my duratracs were. And everything else about the truck is loud inside the cab so I don’t notice it lol
    Slashaar[QUOTED] likes this.
  18. Dec 13, 2022 at 8:33 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ship them and send me a bill lol
  19. Dec 13, 2022 at 8:34 AM
    Slashaar
    Josh
    Kansas City, MO
    So Full send then. Got it.
  20. Dec 13, 2022 at 8:47 AM
    erok81
    erok81 Well-Known Member
    Imposter
    I have them as well. They are just as quiet as my last pro comp all terrains were unless you get next to a concrete freeway barrier and they have a little mud terrain howl.
    They get around the mud terrain noise levels by designing the tire with a crown. Other than the noise this made a huge difference for me. On road the truck drives way better and steers better. Weirdly enough you are supposed to run them at the factory recommended psi so I run mine at 30 psi.
    Now once that crown wears off they might get a little noisy. I’ll have to wait and see for that though.
