Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jun 12, 2023 at 3:55 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    The funny thing is that I'm a trim carpenter, and routinely deal with 32s of an inch. Just thought using a finger as a Guage between the arm and spring would be easier to express.
  2. Jun 12, 2023 at 3:57 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Nope. Definitely not the correct way to view the situation. I took an inch out of mine at the wheel.
  3. Jun 12, 2023 at 4:27 AM
    Trim taco
    Educate me.
    Between the wheel and . . ?
  4. Jun 12, 2023 at 4:44 AM
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    Inch of wheel travel. I did the same. Netting like 12” instead of 13” on my +2.25. I also found at 13” everything binds. Upper ball, steering, upper hits coil badly.
  5. Jun 12, 2023 at 5:18 AM
    Trim taco
    OK, so find a constant point (like the fender) and simply measure the travel, and disregard the space between coil and arm?
    I guess I'm fixating because I just remember reading that you want to limit contact between hard parts. So I thought that was where I should focus my attention.
  6. Jun 12, 2023 at 5:18 AM
    Trim taco
    Thanks again everyone.
  7. Jun 12, 2023 at 5:38 AM
    Anderson5290
    Brandon
    Corona, Ca
    You do want to limit travel between hard parts and thats the most important part. So set it all
    Up. Take a guess on where the tabs should go, tack top and bottom with a heavy tack that can be removed easy and droop it out to verify its right. With the springs on also take into consideration the weight of the tire and wheel. It ends up being close to 1” of wheel
    Travel lost which is why that was said.
    Trim taco[QUOTED] likes this.
  8. Jun 12, 2023 at 5:49 AM
    Anderson5290
    Brandon
    Corona, Ca
    So with your stuff all bolted up springs off, droop out the suspension to full droop, Jack the shock up 1”-1 1/4” and tack your tab in place. Jd tab is adjustable slightly so should be good from that point.
  9. Jun 12, 2023 at 9:12 AM
    906taco
    Cory
    08 Taco
    If I recall there is a perfectly clear explanation on setting up straps in the install sheets….
  10. Jun 12, 2023 at 6:09 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Since starting the SUA kit. Ive been randomly thinking about adding in a rear sway bar. Then comes to mind. What kind? A anti rock? Then its how to incorporate it and make it work. Or a oem style like Hellwig?
    If I remember correctly I've read @81Trekker advocating or at least saying they are worth it in the end for the control.
    Ideas?
  11. Jun 12, 2023 at 8:41 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I was going to add one if I hadn't ended up getting rid of the sua
  12. Jun 12, 2023 at 9:01 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    You going links? I feel like it’d almost be better for links
    Slashaar likes this.
  13. Jun 12, 2023 at 9:09 PM
    WormSquirts
    Braeden
    BC
    Yeah I'm 4 linking and will definitely have a swaybar now
  14. Jun 13, 2023 at 5:57 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I personally would never use a sway bar with leaf springs, the body roll isn’t that bad. With 3/4 link I wouldn’t drive a truck without a swaybar
    dk_crew, CGoss and Slashaar like this.
  15. Jun 13, 2023 at 6:22 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Thank you.
    That settles it.
    dk_crew and BEAR_KNIFE_FIGHT like this.
  16. Jun 14, 2023 at 2:39 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Fort hose that running HEIM steering kit, what are the replacement options available? Coming up to one year mark and with all the salt, mud and other abuse it's time to replace I think. Can't find the mounting width of them on the website.
    Tacoma 05-15 double shear steering tab kit – JD Fabrication
  17. Jun 14, 2023 at 3:23 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would just call them. I am sure they will give you part numbers and sources. They may even sell you what you need.
    EatSleepTacos likes this.
  18. Jun 14, 2023 at 6:22 PM
    Norilsk
    Eugene
    I am up North, last time I spoke they didn’t ship internationally. I’ll email about it I guess.
  19. Jun 14, 2023 at 6:24 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    yea, might have to just get teh part numbers to order yourself. But for stuff like rod ends and what not. USPS it fits it ships box should be easy
  20. Jun 14, 2023 at 9:53 PM
    WormSquirts
    Braeden
    BC
    Where in Canada are you? I can help you out if needed
