Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jun 26, 2023 at 6:36 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    For the custom spindle crowd here is the deal… if 10 people commit and put down deposits we will make them. The upgrade will consist of a fully fabricated spindles with a vertical upper and new control arms. The outer tie rod will step up to a 1” and the lower EMF will be swapped out to a 1” Uniball so it can be double sheared in the spindle. We will retain the Toyota unit bearing so you don’t loose the speed sensors and will have OE brake mounts.
    It won’t be cheap, probably somewhere between $2500-3000 but if you guys are serious we will do it.
  2. Jun 26, 2023 at 6:40 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    4wd?
  3. Jun 26, 2023 at 6:56 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Mounting change? Or still OE location? Able to bump off the spindle or UCA? If so, you can count me in.
  4. Jun 26, 2023 at 7:06 AM
    81Trekker
    La Jolla SD
    The upper arm will be on heims and can be mounted in any configuration you want. And yes the spindle will be designed to bump off the top.
  5. Jun 26, 2023 at 7:34 AM
    906taco
    Cory
    08 Taco
    Slashaar likes this.
  6. Jun 26, 2023 at 7:36 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I’m in also!!
  7. Jun 26, 2023 at 7:57 AM
    81Trekker
    La Jolla SD
    8 more and I’ll get going on it asap
    Slashaar and Airdog[QUOTED] like this.
  8. Jun 26, 2023 at 7:57 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    You know I’m in. I’m already full snowballing. Why not. Lol
  9. Jun 26, 2023 at 8:03 AM
    81Trekker
    La Jolla SD
    7 more
  10. Jun 26, 2023 at 8:12 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    How much travel is realistically achievable with the same axle is my only question. I feel like the diff would have to drop to get much more down travel out of it. Lots of room for up travel, but like you already said, the belly will be on the ground.
    I'm definitely interested, but I'd be hoping for 16"+ of travel, and can't see the axle doing that as is.
  11. Jun 26, 2023 at 8:46 AM
    81Trekker
    La Jolla SD
    You will gain 3” uptravel… and with your 69” tires you will have plenty of ground clearance
  12. Jun 26, 2023 at 9:15 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    What kind of fool has axles upfront????
    Slashaar and Sterling_vH111 like this.
  13. Jun 26, 2023 at 9:16 AM
    WormSquirts
    Braeden
    BC
    Sounds like I'd be cutting another 420mm out of my cab
  14. Jun 26, 2023 at 9:31 AM
    81Trekker
    La Jolla SD
    Exactly
  15. Jun 26, 2023 at 9:44 AM
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    I keep thinking of ditching my 4WD. Throwing the whole 4WD system and the lt kit on my 4Runner then asking @81Trekker to build me some beams. To keep the truck JD everything.
  16. Jun 26, 2023 at 9:45 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I mean you could probably just move the cab back more right? Lol
    Camazon and Slashaar like this.
  17. Jun 26, 2023 at 9:55 AM
    WormSquirts
    Braeden
    BC
    It's probably easier to cut out the back of the cab than the front!
  18. Jun 26, 2023 at 10:06 AM
    TTLT
    TTLT Active Member
    2021 TRD OR
    if you can ditch the taco hub i'm in for the vertical ball joint spindle and arm upgrade
  19. Jun 26, 2023 at 10:29 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Or just keep the top half of the cab but fab fire wall floor and rear wall.
  20. Jun 26, 2023 at 10:33 AM
    81Trekker
    La Jolla SD
    You just tripled the cost… custom hubs, brakes, axles and CV’s
