Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jun 26, 2023 at 10:55 AM
    TTLT
    TTLT Active Member
    2021 TRD OR
    Is that a no?
    Slashaar likes this.
  2. Jun 26, 2023 at 1:05 PM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Not sure there is actually a market for $9k+ Tacoma spindles
  3. Jun 26, 2023 at 1:10 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
  4. Jun 26, 2023 at 1:18 PM
    TTLT
    TTLT Active Member
    2021 TRD OR
    Ok
    didn't expect the spindle to be 9k. Figured ~10k would get a guy axles, arms, spindles and hubs more or less like the Solo XLT kit but not so wide
  5. Jun 26, 2023 at 1:28 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    What’s the beef with taco hubs? I’m 3 years in on 37’s with mine no issue. 2 years of 35’s before that.
  6. Jun 26, 2023 at 1:34 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Probably cause Dana44 locking hubs exist and are already readily available on the market at most auto parts stores and the design to incorporate into a Tacoma is decently prevalent within off-road
    Not to mention you can add blitzkreig locking rings to ensure the CV doesn’t loosen
    I’m just stirring the pot tho
    if I wanted a custom kit for a Tacoma that doesn’t exist
    I’d want a 4WD J Arm since the quixotic kit is impossible to actually get
  7. Jun 26, 2023 at 1:48 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Seen a lot of bad wheel bearings and sheared studs. Can fix the stud issue with 5/8" studs. On my 37's, I would change an SKF unit bearing every 12-18 months.
  8. Jun 26, 2023 at 2:24 PM
    81Trekker
    La Jolla SD
    The whole point of doing this was to keep the cost down. $9k would cover the cost of custom spindles, hubs, brakes etc. you will also need new axles and we would do a 934 outer CV so that gets factored in as well. At that point all you would be reusing is your lower arm.
    What we are talking about is having a spindle/upper arm upgrade that doesn’t require all new everything
    Slashaar, jamesepoop and AY_ARONTRD like this.
  9. Jun 26, 2023 at 2:56 PM
    81Trekker
    La Jolla SD
    We just went from a $3k spindle upgrade to a $300k truck… lol
  10. Jun 26, 2023 at 3:21 PM
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    3” is a joke right?
  11. Jun 26, 2023 at 3:24 PM
    81Trekker
    La Jolla SD
    Not at all, with a vertical upper Uniball you can probably gain 3” of additional wheel travel on the 4” LT kit
  12. Jun 26, 2023 at 3:28 PM
    Anderson5290
    Brandon
    Corona, Ca
    We talking down travel? Or up and down? What’s involved with getting that much more travel? Can’t see getting anymore up unless the coil bucket gets replaced. At hard bump my shock is almost fully compressed. Plus or minus 1/4”.
  13. Jun 26, 2023 at 3:32 PM
    81Trekker
    La Jolla SD
    Up travel, the axle will bind with anymore drop out. And all I’m talking about is what the kit will cycle, nothing to do with shocks. You will be on your own to fabricate an engine cage and mount 10” coil overs.
    Anderson5290[QUOTED] likes this.
  14. Jun 26, 2023 at 3:34 PM
    Anderson5290
    Brandon
    Corona, Ca
    So much for the inner fender kit I just bought haha.
  15. Jun 26, 2023 at 5:32 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I’ll take one
  16. Jun 26, 2023 at 6:02 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    just one spindle ?
    Deeahgee and Slashaar like this.
  17. Jun 26, 2023 at 6:37 PM
    906taco
    Cory
    08 Taco
    I mean at the end of the day is 12-18 months even something to think about at this stage? Especially when a timken is 80$?
    tacotunner06 likes this.
  18. Jun 26, 2023 at 7:17 PM
    81Trekker
    La Jolla SD
    Right, going 18 months without preping the front end on a real off-road truck is insane to me.
  19. Jun 26, 2023 at 9:55 PM
    WormSquirts
    Braeden
    BC
    Ain't nobody got time for that, she spins she wins
  20. Jun 26, 2023 at 10:00 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    What’s this prep shit? Lmao…
    Offthewall likes this.
