Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jul 6, 2023 at 8:27 AM
    amag413
    amag413 Well-Known Member
    Aaron
    Philly
    2014 Black Tacoma TRD Sport | Double Cab SB
    JD Fab 2.25 kit, Homemade flatbed, Four Wheel Camper
    Ok Cool, anyone know how much play I should be seeing/ setting them at for upper and lower? I watched the EMF videos on the dodge knuckles but I assume that doesn't really apply.
    Appreciate the help @Sixthelement and @906taco !
  2. Jul 6, 2023 at 8:29 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    No LT, but, when locked, my 35s are hitting the metal fender under the battery and wiper fluid reservoir. Looks like the Superbump isn't getting compressed at all against the LCA (OEM) when it hits. Since I don't plan on adjusting the fender until next year when I get Kings, resis, and bucket reinforcement, how fat of a spacer should I put on the bumpstop to get it from slamming against the metal? I ordered both 1/4" and 3/8" from Wheelers, but the total lack of compression has me thinking that I may need to stack them?
  3. Jul 6, 2023 at 9:00 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    start with the smallest spacer and then pull the coilover and cycle the suspension with the tire on to check for clearance in that spot.
    essjay[QUOTED] likes this.
  4. Jul 6, 2023 at 11:58 AM
    amag413
    Aaron
    Philly
    This is what EMF says for anyone else wondering
    "We tighten the cap right to the bottom and then back it off a hair. It can have side to side movement, but no up and down movement. It just depends on the feel of the joint that you want, but tighten It down by hand and see If there is no up and down movement on the pin, that is what you’re trying to eliminate."
  5. Jul 6, 2023 at 6:32 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Anybody in here do a big brake kit yet? Looking to order a powerbrake setup, but know the stock caliper with a banjo does come close to the bypass tabs. My concern is spending big money on brakes and having issues.
    Over the weekend I’ll have to cycle things I suppose. But if anybody is running something I’d love to know.
  6. Jul 6, 2023 at 6:52 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I've been running 4 runner calipers and rotors. The power brake setup has recessed ports so shouldn't be too much closer to the lca. They are way lighter than the stock calipers too which is nice.
    We are a power brake dealer, so if you don't have a line on them already, let me know
  7. Jul 6, 2023 at 7:10 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I was talking with Power Brake at expo, but then never heard back from them. That was one of any big questions was weight with the one piece rotors compared to Wilwood
  8. Jul 7, 2023 at 3:43 AM
    906taco
    Cory
    08 Taco
    Shoot me a number. I’ll order tonight.
    Going to talk with Delon today to see what his thoughts are. I know @EatSleepTacos had issues breaking banjos and I recall something coming close on mine as well. Either way, it’s time for more stopping power. And powerbrake seems to be the best option available.
  9. Jul 7, 2023 at 4:45 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    are you looking for stopping power or just torque?
    if it's just torque you want and haven't had temp (fade) issues I recommend starting with just higher friction pads.
    it's hard to compare friction coefs across companies since they don't provide real numbers, but i've always been happy with Hawk pads for all sorts of applications so I typically stick to them plus they have reasonably visual temp/friction curves posted for each pad.
    with my overweight setup I ended up picking up the LTS pads to try this season.
    for a non-straight up racecar application (meaning longer between service/inspection intervals) i like having dust boots on my pistons, which the powerbrake setup does not offer.
    Alcon has dust boots but is heavy iron calipers (but that does mean you can run more pressure comfortably if you are overhauling the entire brake setup)
    I've disagreed with some Wilwood engineering on some of the products they offer so i typically don't take them too seriously
    Stoptechs look nice and I run them on my BRZ but they are focusing on maintaining brake bias with the rear drums, which is great for most tacoma owners, not so much for my specific overloaded application, so I decided against going with them.
    maintaining brake bias = not a significant increase in torque.
  10. Jul 7, 2023 at 5:14 AM
    906taco
    Cory
    08 Taco
    I’ve had EBC’s on for a while now. It’s not enough. Pad life has dramatically decreased and I have started developing a pulse in the front.
    Pad contact area plays a massive role in braking/longevity. Powerbrake offers the largest rotor of any that will fit under a 17” wheel.
    With the truck being a half ton over weight I feel BBK is my only option. Especially on a build of this caliber
    HIYota likes this.
  11. Jul 7, 2023 at 5:21 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    What was your disagreement with wilwoods? Just out of curiosity
    llibrm likes this.
  12. Jul 7, 2023 at 5:27 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Are you still running stock lower shock bolts? They are tapered and will cause a popping sound. I recently learned about this. I've had popping sounds for a long time and thought it was the same as you. Could be this.
    https://www.tacomaworld.com/threads/the-infamous-click-up-front…going-down.800581/
    I haven't bought them yet, so I can't know for sure that's what mine is.
  13. Jul 7, 2023 at 5:53 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    With the right caliper, we can fit a 360 x 36 mm under a 17” wheel. Not a huge difference, but more is more… the pads are enormous.
    https://www.tacomaworld.com/threads/wicked-big-brakes-for-17-wheels.679537/
  14. Jul 7, 2023 at 6:43 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I’ve driven trucks with ALL the different big brake kits and the only one that actually impressed me was the wilwood kit, especially since the truck was on 39’s.
    tacotunner06 and llibrm like this.
  15. Jul 7, 2023 at 7:48 AM
    906taco
    Cory
    08 Taco
    From the people I’ve talked to, the powerbrake setup is miles ahead of the wilwoods in many different areas. And they actually design their calipers to work with the factory master/booster where as everyone with wilwood claims they lost pedal feel.
  16. Jul 7, 2023 at 8:04 AM
    amag413
    Aaron
    Philly
    @906taco I've driven both and can confirm that the powerbrake retains a factory pedal feel where the wilwood has a lot more travel unless you have an off road with the electronic brake booster or upgrade the master cylinder. Trying to find some pictures of a build we did with The Grey anodized calipers. Looks super sexy too.
  17. Jul 7, 2023 at 9:31 AM
    906taco
    Cory
    08 Taco
    Honestly blown away people spend the money to go fast on dirt but apparently don’t spend on the supporting parts, like good brakes to stop our overweight pigs.
  18. Jul 7, 2023 at 9:52 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I’ve got wilwood on all 4 corners along with the sequoia master cylinder a deleted ABS module and a proportioning valve for the rear brakes and i’m very happy with its stopping power. But I do plan on putting a tundra vacuum booster on in the next couple months to make it even better.
  19. Jul 7, 2023 at 10:35 AM
    essjay
    Concord, CA
    You have a parts list and link to the kit in your build thread? I did the GX470 semi-BBK last year, and the improvements have been marginal at best.
  20. Jul 7, 2023 at 11:26 AM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    bro you have a caged taco and are just now putting bigger brakes on it
    EatSleepTacos and TireFire like this.
