Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Mar 20, 2025 at 6:47 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Dig through @airkewled 's build thread: https://www.tacomaworld.com/threads/airkewleds-2006-dcsb.502947/page-3#post-29797869
    And these: https://www.flickr.com/photos/19843514@N03/albums/72157719731353009/
    Both helped immensely with my ordeal. Also, once you unbolt your factory pump, make sure the hardware fits through the mounting holes on the new pump.
  2. Mar 20, 2025 at 10:26 AM
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    AY_ARONTRD likes this.
  3. Mar 20, 2025 at 10:45 AM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Checked immediately when I removed the pump. No dice. Didn’t fit haha. That’s resolved now. Yeah I’ve been checking out @airkewled build. Great info. Thanks for the help.
    Sweet! Thanks! I’ll probably be reaching out to you this afternoon. Great build you have going :thumbsup:
  4. Mar 22, 2025 at 3:33 PM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    HOWE TC pump is installed. Thanks again to those who helped with the install information.(if your close to murrieta come down for some fresh beer on tap at my house) Haha.
    It all helped! Took it for a few test drives to make sure no leaks… now onto billet tie rods.
    Naveronski, 01 dhrracer and TWTaco like this.
  5. Mar 22, 2025 at 3:34 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    :cheers:
    AY_ARONTRD[QUOTED] likes this.
  6. Mar 22, 2025 at 3:46 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    OMW....I'm in Elsinore!
  7. Mar 22, 2025 at 3:46 PM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Come on down haha
  8. Mar 22, 2025 at 4:52 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Charlotte is a long drive in a lifted Taco… hmm
    Slashaar and AY_ARONTRD[QUOTED] like this.
  9. Mar 22, 2025 at 10:53 PM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Anyone have a solution for boot covers when swapping to the billet tie rods?
    Slashaar likes this.
  10. Mar 24, 2025 at 5:01 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    A lot of people have tried a few different things, but I don't believe there was any consensus on boots. Assuming you mean to cover the heims?
  11. Mar 24, 2025 at 5:31 AM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Yeah to cover helms and steering rack.
    Slashaar[QUOTED] and YotaFAB like this.
  12. Mar 25, 2025 at 4:47 AM
    Slashaar
    Josh
    Kansas City, MO
  13. Mar 27, 2025 at 9:18 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    IIRC, the Howe pump will help eliminate wander, or what some assume is bump steer? Have those that have performed the swap noticed this? I just passed 260k on the factory pump and I’m on 34s load range c Mickey Thompsons. I don’t remember this much wander from my previous Coopers also sized at 34”. I recently replaced the putter tie rods and wheel bearings, with a fresh alignment. It’s to the point where it’s making me crazy and I’m running out of ideas for corrective measures.
  14. Mar 28, 2025 at 5:10 AM
    Slashaar
    Josh
    Kansas City, MO
    Road feedback is what you get when you hit a bump in the road and the wheel jerks, bump steer is where the toe changes due to suspension travel. Harry told me this when I was asking about the Howe pump a while ago. The pump will hope with the former, not the latter.
    llibrm[QUOTED] and Naveronski like this.
  15. Mar 28, 2025 at 8:51 AM
    aturk
    Tony
    Charlotte, NC
    Wander is definitely alignment specs. I think most of the local shops give one side a touch more caster to prevent some of the pulling.
    I would rotate your tires around first just to rule that out.
  16. Mar 28, 2025 at 6:47 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Maybe you could post your alignment specs. I've had extreme caster both too low and too high cause really bad steering in general, and wander for sure. Not pull. When caster was too low, like less than 2.5, truck wouldn't want to go straight, it would just always wander depending on micro slope of the road, and which way the wind was blowing to tip the truck slightly, etc. Then I installed the JD LCA tab frame kit, and moved the wheels way forward, coupled with existing uppers that moved the UBJ back some, I had like 6 degrees or something crazy, and it was worse than too little. could hardly keep the truck straight, when I would initiate a turn on highway, truck would lean slightly, then dive into the corner hard, I actually had to counter steer back to straight just when making a lane change, etc. It was honestly not very drivable. Then, with adjustable upper, I moved UBJ forward, got caster to a reasonable number, slightly higher on passenger side (I can't remember what the numbers were exactly) and now the truck drives straight as arrow, no wander, no dive into turns, no drama. Something to think about.
    Also tires, some really like to follow cracks and lines in the road, some don't, and a soft sidewall that allows the truck to lean more, will for sure make it wander more than a stiffer sidewall tire, of course depending on weight of the truck.
    llibrm and Slashaar like this.
  17. Mar 28, 2025 at 6:48 PM
    Maxx
    Maxx Well-Known Member
    Add a touch more toe in.
    llibrm[QUOTED] and Airdog like this.
  18. Mar 31, 2025 at 12:18 PM
    Slashaar
    Josh
    Kansas City, MO
    Are the shocks listed on the site singles or a pair? I'm assuming singles, since the price is so low. Also do they come with the 90 degree fittings? Anyone know? They have the Fox 2.5 14" non-dsc travel shocks listed for less than a lot of places. Assuming Fox Factory Race series.
  19. Apr 1, 2025 at 11:32 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Gentlemen,
    I greatly appreciate the input. Here is my recent alignment report card.
  20. Apr 1, 2025 at 6:36 PM
    racebug68
    Travis
    Chandler, AZ
    I don't know what exactly is your issue, but if it were me I'd shoot for more caster, and increase the toe in a little. That said, they are already at the recommended limit for that software. I've gone into the 4% range with good results. Usually, they make the passenger side caster a little higher than drivers side, this prevents the truck from pulling to the right on a crowned road, but doesn't generally make it pull left on a flat road. I also run a SPC upper, which some don't like for strength reasons. But they are good for dialing in exactly the specs you want to achieve, rather than being settling with what you can get.
