Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Apr 2, 2025 at 8:31 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I'm maxed out in caster. I'm running TC uppers and lowers.
    What I'm hoping to correct is when driving straight, with minimal steering input, the truck wanders as it catches every groove in the road. They don't need to be deep semi-trucks ruts either. A simple road patch, which here in Washington, they like to replace ruts with strip patches that may be miles long. I'm hoping that the increased pressure from the Howe pump would be enough to help the truck from following these grooves by having more presence from the power steering.
  2. Apr 2, 2025 at 12:31 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    sounds like tires to me, where the steering angle isn't changing, pump will do nothing, but as the tire itself navigates differences in height across the tread witdth, or different grip on one side of tire vs other, it is causing a pull from the tire itself. You could try different pressure in the front, or try swapping tires with someone else that has different ones, just as a back to back road test...
    llibrm, 01 dhrracer and Airdog like this.
  3. Apr 6, 2025 at 7:18 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Got to take the project truck out for the first time a few weeks ago. This has been too long in the making. Put a lot of time into this project, especially over the past few months.
    Wasn't a bad start for just coming off jack stands and heading to the desert 3 days later. Rear shocks were a bit stiff on compression but nothing a quick re-valve can't change.
    JD Fab SUA kit with 3.0 x 14" (3 Tube) bypasses.
    https://www.instagram.com/p/DHjD37UJqmm/
    JasonT87, Naveronski, YotaFAB and 4 others like this.
  4. Apr 10, 2025 at 9:04 PM
    Cleatus
    Cleatus Well-Known Member
    SoCal
    2015 DCSB OR 6spd
    2” or so lift
    I’m installing the sua kit, just curious what you guys torqued the shackle too. I’m not wanting to torque the 3/4” fine thread to its 315 ft/lb spec, seems a bit excessive. And just curious if it was just me, but putting the shackle into the mount was a royal pain.
  5. Apr 10, 2025 at 9:15 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I did mine to 250 ft/lbs with an extra 45° rotation. Marked with CrossCheck and no problems so far.
  6. Apr 10, 2025 at 9:20 PM
    Cleatus
    SoCal
    2015 DCSB OR 6spd
    2” or so lift
    Sounds good, thank you
  7. Apr 24, 2025 at 4:25 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Looking to order shocks through accutune and need the shock angle. Does anyone know what that is?
  8. Apr 24, 2025 at 7:10 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Degrees from vertical is all I can think of. They’re probably interested in that for the motion ratio. If it’s a JD kit, should be able to get that info from Jesse. If they’re feeling nice, some companies will reach out for you. Just depends
    Slashaar[QUOTED] likes this.
  9. Apr 25, 2025 at 6:29 AM
    Slashaar
    Josh
    Kansas City, MO
    The example was 90°, so I assume that's straight vertical. I'll see about calling them.
  10. Apr 25, 2025 at 4:08 PM
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    What shocks are you ordering? Front/rear? JD has specific notes for front coilovers and rear bypass layout. I have the coilover specs.
  11. Apr 26, 2025 at 8:17 AM
    Slashaar
    Josh
    Kansas City, MO
    Ordering 2.5 smooth body King rear shocks from Accutune. An upgrade from the 2.0s I've been running.
    I measured out the eye-eye at ride height and since my towers are 18" forward of the axle (since harry told me 17-18" when I was doing the install) the math comes out to ~37°.
  12. Apr 26, 2025 at 10:09 AM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    I think you just need 14” stroke shocks then. Are you planning a reservoir? Remote or piggyback? Compression adjusters? Custom valving?
  13. Apr 26, 2025 at 10:38 AM
    Slashaar
    Josh
    Kansas City, MO
    Yes, 14" travel shocks is what JD recommends for the setup. It's custom valve stack tuning that accutune provides. Thus I don't think I need adjusters and save the money. Remote reservoir with 90° fittings. The real question after I get them is where to get them charged with Nitrogen.
    For context, I don't do a lot of highspeed stuff, just highway driving and slow/medium speed off roading/rock crawling.
  14. May 3, 2025 at 12:39 AM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
  15. May 3, 2025 at 8:22 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Slashaar and AY_ARONTRD like this.
  16. May 5, 2025 at 5:01 AM
    Slashaar
    Josh
    Kansas City, MO
    Yet.*
    FTFY.
    essjay[QUOTED] likes this.
  17. May 5, 2025 at 9:11 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    AY_ARONTRD[QUOTED] likes this.
  18. May 5, 2025 at 9:25 AM
    Slashaar
    Josh
    Kansas City, MO
    Would or wouldn't?
    AY_ARONTRD likes this.
  19. May 5, 2025 at 9:59 AM
    Y2kbaja
    Sacramento
    Total Chaos
    Would use as stand alone radiator support only and not tie my inner fender wells to the cab. My fender liners have pulled the spot welds off the cab.
    Slashaar likes this.
  20. May 6, 2025 at 1:58 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    AY_ARONTRD[QUOTED] and Slashaar like this.
