Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. May 7, 2025 at 5:29 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Think an engine cage and tying the fenders into it would help?
  2. May 13, 2025 at 12:10 PM
    Offthewall
    Offthewall Well-Known Member
    Southern OR
    12 tx pro
    That’s why I’m here
    Question for you guys about charging shocks.
    How often do you recharge/ check psi?
    How much psi do you seem to lose over time?
    Is this the same for your shocks and hydro bumps?
  3. May 13, 2025 at 1:13 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I’ve never thought about it outside of when I get the shocks rebuilt, but I’ve also never that my shock was low at rebuild time.
    Slashaar likes this.
  4. May 15, 2025 at 5:43 AM
    Slashaar
    Josh
    Kansas City, MO
    If they leak you might need to rebuild them anyway.
    whoareyou133 likes this.
  5. May 15, 2025 at 7:17 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I will usually recharge them once a year unless doing a rebuild. Which for me is like every 1500-2000 miles. And rebuild every other year. It’s usually part of either my koh prep or Labor Day prep.
  6. May 15, 2025 at 1:58 PM
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    I have done once a year so far, the shocks have lost around 30psi. But the bumps both times have been 50 or less, coming from 150. Not sure how fast they are losing, going to keep up on them better this year. Guessing they need rebuilt, any ideas why they went so fast?
  7. May 15, 2025 at 2:12 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    You’re going to lose pressure just checking it. Even with a no loss chuck. Especially with the bumps because there is such a small volume in there. I never just “check” mine. They get drooped out and just recharged.
  8. May 15, 2025 at 3:17 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    If you're really worried about leaks, establish a rebuild interval based on your use. Best way to ensure you are pressurized and seals are in good condition.
  9. May 15, 2025 at 5:48 PM
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    That makes sense. I’m charging at ride height, bumps aren’t touching, should I be doing that different?
    That makes sense, not sure what interval that should be. Truck goes to the woods or high desert at least once a month, couple trips to the dunes a year. And usually 1-2 rock crawling type trips a year.
  10. May 16, 2025 at 5:06 AM
    Slashaar
    Josh
    Kansas City, MO
    If you need an interval, just do 10k. That gives you 4 checks before the recommended 50k rebuild. For me that's also my oil change interval.
    Offthewall[QUOTED] likes this.
  11. May 16, 2025 at 6:18 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    You want to charge at full extension. So bumps at ride height are fine, but shocks you want to droop out. I usually don’t pull limit straps because that’s close enough, but ride height for shocks is not going to be good. 200psi at ride height will be much less than that drooped
  12. May 16, 2025 at 8:50 AM
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    Copy that is good to know.
  13. May 16, 2025 at 8:07 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Anyone know if JD usually does Memorial Day sales?
  14. May 19, 2025 at 4:58 AM
    Slashaar
    Josh
    Kansas City, MO
    Honestly can't remember if they did any sales other than those 2 or 3 group buys.
    I think YotaMafia also retails their stuff, so maybe if they have a site wide sale?
    AY_ARONTRD[QUOTED] likes this.
  15. May 19, 2025 at 10:36 AM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    I want to say last year sometime I seen a 10 or 15% off sale from JD… can’t remember.
    Slashaar[QUOTED] likes this.
  16. May 19, 2025 at 1:11 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I've heard it's good to call Jesse at the shop to see what he can work out for you.
    Slashaar and AY_ARONTRD[QUOTED] like this.
  17. May 20, 2025 at 3:27 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Random question: is everyone on 35s running the LCA pivot kid with the LCA pushed as far forward as possible?
    JD installed mine pushed all the way back and I've been fighting alignment issues the last few months, considering shuffling them forward to get my caster a little more managable.
  18. May 20, 2025 at 5:06 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    When we install their kits, we usually go one step back from all the way forward.
    Slashaar and cowfootball[QUOTED] like this.
  19. May 20, 2025 at 6:42 PM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    This came across my feed recently about a product that fixes an interference between 934CVs to the steering pinion. Is this an issue I just haven’t heard about?
    I admit I can’t say I’ve ever looked at the clearance between the two on my truck and it’s been so rainy and muddy (and cold) the past couple days here in BC I haven’t had the motivation to really look up there yet.
    how much of an issue is this? Or is it not?
    https://www.instagram.com/p/DJpcvEtRDHq/?igsh=MWkxcGg0MmpoMGdjcA==
  20. May 20, 2025 at 9:30 PM
    WormSquirts
    Braeden
    BC
    There can be. Honestly it's a truck by truck basis, some touch, some don't. Usually we shave the little bolt head down a touch and that's enough. Sometimes we have to space the rack up a hair.
    Not sure what their "precision machined billet spacer" is. A big washer that covers the whole bushing will do the trick.
