Fitting 35’s with minimal trimming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Nov 7, 2019 at 5:54 PM
    #621
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    So you want me to make you something you can bolt on?! :)
    MattCowsmasher likes this.
  2. Nov 7, 2019 at 5:56 PM
    #622
    MattCowsmasher
    MattCowsmasher TTC #0010
    Temple, TX
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, long legged, big tars, debadged with a hood skewp
    When the time comes I’d love to, I just ordered a new front bumper and with the holidays the budget is kinda lean right now.
  3. Nov 7, 2019 at 5:58 PM
    #623
    81Trekker
    La Jolla SD
    Help me find a MGM grill, sport hood and mirrors and I’ll make you whatever you want!
    That offer stands for anyone
    DiamondW and MattCowsmasher like this.
  4. Nov 7, 2019 at 8:22 PM
    #624
    81Trekker
    La Jolla SD
    upper arms are $529
    MattCowsmasher and JaCado like this.
  5. Nov 7, 2019 at 8:22 PM
    #625
    Matmo215
    Matmo215 Baylor '23
    Matthew
    Denton/Waco, TX
    2011 Taco Truck
    5100's, 885's, JBA UCA, AAL
    The BAMF??
  6. Nov 7, 2019 at 8:24 PM
    #626
    JaCado
    JaCado Well-Known old guy
    Jay
    Are the uppers specifically for this kit or are they compatible with other set ups?
  7. Nov 7, 2019 at 8:41 PM
    #627
    81Trekker
    La Jolla SD
    There are two different uppers in existence. The ones on my truck have stock geometry because the caster is changed with the lower arm and there is also an upper available with increased caster if you are running the stock lower mounting location
    JaCado likes this.
  8. Nov 7, 2019 at 8:42 PM
    #628
    JaCado
    Jay
    Thank you.
  9. Nov 7, 2019 at 8:44 PM
    #629
    81Trekker
    La Jolla SD
    The lower kit works with any aftermarket uppers as there is more than enough range in the lower mounts to get the correct caster
    llibrm, desertjunkie760 and JaCado like this.
  10. Nov 7, 2019 at 8:47 PM
    #630
    JaCado
    Jay
    I am not looking to run 35's or 40's on my daily pool truck. I'll stick with my 33's, just looking at options for replacing the uppers to improve my caster at the moment. I'll worry about the lowers when they need serviced or break.
    Beretta4x4 likes this.
  11. Nov 7, 2019 at 8:50 PM
    #631
    81Trekker
    La Jolla SD
    Just get the caster adjusted upper replacement and be done... they will definitely help you get to superior quicker to pick up tabs :)
    JaCado likes this.
  12. Nov 8, 2019 at 7:06 AM
    #632
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
  13. Nov 8, 2019 at 7:12 AM
    #633
    MattCowsmasher
    Temple, TX
    No went with SOS to have all matching stuff.
    McRib, Beretta4x4 and Matmo215 like this.
  14. Nov 8, 2019 at 7:56 AM
    #634
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged LT TX Pro
    2011 S/C Long Travel and home built goodies
  15. Nov 8, 2019 at 8:01 AM
    #635
    81Trekker
    La Jolla SD
    Thanks for that, I’m going to start tearing into the rear next week and I’ll see what will fit. I’m guessing I might have to poke through the bed to fit 14” if I want the axle to bump out on the frame
  16. Nov 8, 2019 at 8:05 AM
    #636
    desertjunkie760
    Shane
    Check My Sig.
    You'll have to play with it. SUA will change all variables. It'll be interesting to see what you come up with.
  17. Nov 8, 2019 at 9:00 AM
    #637
    81Trekker
    La Jolla SD
    Shooting for 15-16” of travel with 6-7” shackles, low ride height and having the axle bump out on the frame is the plan
    desertjunkie760 and YumaTRD like this.
  18. Nov 8, 2019 at 9:06 AM
    #638
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup, cus you get the extra uptravel of the leafpack thickness potential.... but then for OP's use, SUA might not be ideal due to extra stuff hanging down.
  19. Nov 8, 2019 at 9:06 AM
    #639
    nd4spdbh
    SoCal
    Ya know... most people if they said this id say go pound sand.... but the beautiful fab porn you have produced.... I believe in ya!
  20. Nov 8, 2019 at 9:23 AM
    #640
    81Trekker
    La Jolla SD
    The only thing hanging down will be the thickness of the springs. I will build custom spring plate cradles and use grade 8 bolts instead of u bolts so nothing is hanging down
    nd4spdbh likes this.
