Fitting 35's on 3" suspension lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by ponethousand, Dec 20, 2013.
  1. Sep 14, 2018 at 10:56 AM
    #321
    Wulf
    Wulf no brain just damage
    rock raisin
    Has anyone had issues with clutch pedal interference when tubbing?
  2. Sep 14, 2018 at 11:01 AM
    #322
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    I didn’t have any problems with mine. You probably don’t need to even cut that far in to where it would interfere with the clutch throw.
  3. Sep 14, 2018 at 1:14 PM
    #323
    cynicalrider
    cynicalrider #NFG
    Jersey
    This.
  4. Sep 14, 2018 at 1:39 PM
    #324
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I cut more than @cynicalrider did, but I have no problems at all with the clutch pedal range.
  5. Dec 8, 2018 at 7:26 PM
    #325
    Wulf
    rock raisin
    Picked up some 35x12.50R17 Treps today. I'll need wheels. Will 17x9s with 3.5" backspacing clear the sidewall from the UCA?
    I have a set of 295/70R17s on 5th gen 4runner wheels and they require 1.25" spacers to clear the UCA, but those wheels have like 4.85" of backspacing
  6. Dec 8, 2018 at 7:38 PM
    #326
    UnderFire
    UnderFire Well-Known Member
    3.5" is just about perfect. They'll clear with a little to spare. The 295s are a similar width to the 35's, and on the 7.5" wide factory wheels they'll probably poke out a little further past the rear lip.
  7. Dec 8, 2018 at 7:50 PM
    #327
    Wulf
    rock raisin
    Cool, thanks for the info. The hard part now will be deciding on steel wheels, SCS, or poring over the raceline catalog to see of they have something that fits
  8. Dec 8, 2018 at 8:34 PM
    #328
    UnderFire
    Finding em is the hard part lol. Your short list of SCS and steel wheels is just about it. I don't believe raceline has any options anymore unless the brought back the monsters, which are beadlocks anyway.
  9. Dec 8, 2018 at 8:38 PM
    #329
    Wulf
    rock raisin
    Yehup, seems like Procomp/Vision are the only ones who make steelies in 17x9 with 3.5" BS and SCS is the only one who makes alloys.
    Raceline does have beadlocks, but those are probably out of budget even though I can get them at cost.
  10. Dec 8, 2018 at 8:40 PM
    #330
    UnderFire
    The struggle of sharing bolt patterns with Chevies that have like 6" backspace from the factory lol.
  11. Dec 8, 2018 at 8:41 PM
    #331
    Wulf
    rock raisin
    right? It seems like most manufacturers fall into the 5-4.25" BS range :(
  12. Dec 8, 2018 at 8:43 PM
    #332
    UnderFire
    9" wide and 4.5 BS is aggressive fitment on just about everything but a 1st gen taco, unfortunately.
    Wulf[QUOTED] likes this.
  13. Dec 8, 2018 at 8:51 PM
    #333
    Wulf
    rock raisin
    Yeah, it's a bit of a bummer how narrow the drivetrain on these trucks are in comparison to modern ones.
    Looks like I can expect to pay 90-95$ per wheel for steelies or 200+ ea for SCS... SCS do look better but damn, this is a 20-something year old truck
  14. Dec 9, 2018 at 4:20 AM
    #334
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    depends. my old maxxis tires had sidewall lugs that had about 1/8" clearance and they did show signs of rubbing. now im at 2.25"bs so that definitely isn't an issue
    cruiserguy and jubei like this.
  15. Dec 9, 2018 at 12:09 PM
    #335
    Wulf
    rock raisin
    Which Maxxis? That's close enough that I'd consider running longer lug studs and the 1/4" thick plate spacers or whatever
    One think I'm thinking about is going the steel wheel route so I can add beadlocks later on :gossip:
  16. Dec 9, 2018 at 12:32 PM
    #336
    devinzz1
    devin
    2023 aclb trd or mt
    bighorn
  17. May 9, 2019 at 8:17 AM
    #337
    Wulf
    rock raisin
    with the 4runner Trail Edition wheels and 1.25" spacers totalling around 3.5" BS I am still rubbing the frame before full lock when stuffed :annoyed:
    I don't really want to step up to wider spacers but it seems like I should give them a shot
  18. May 9, 2019 at 8:40 AM
    #338
    jubei
    NoCo
    Stuff. Also things.
    I’m running 2.5 total BS, and I still kiss the frame at full lock... You get used to it.
  19. May 9, 2019 at 12:43 PM
    #339
    Wulf
    rock raisin
    Do you think it's worth getting some wider spacers?
    Part of me thinks I should stack 2 of mine and tub for that just in case I change my mind on the wheel and tire setup the future. Other part says fuck it, it's fine
  20. May 9, 2019 at 1:22 PM
    #340
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You should definitely tub more than you think in order to accommodate for wheel/tire changes in the future.
    You need around 2” of total BS in order to not touch the frame. Basically not worth doing unless you’re LT. Just something to live with.
    Yetimetchkangmi and jubei like this.
