Fitting TALL 33s on a 2nd gen!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacogar61, Jul 8, 2024.
  1. Feb 14, 2025 at 8:51 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I have my 255/85R16 spare in the normal location. It's a tight fit, but it fits. That said, it does require a little modification - you have to bend some tabs which hold the normal spare in place. Pushing them outward gives more room for the larger tire to come all the way up into the cavity for the spare under the bed. You also have to lift into place carefully to make sure you pull it rearward so there's no conflict with the diff. There are multiple threads that discuss the mods and various ins/outs of fitting a larger spare.
    HammerChiro[QUOTED] likes this.
  2. Feb 14, 2025 at 11:35 AM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    Your tire is a half inch shorter than his. Also, YMMV with this. I am running 255/80/17’s, the same diameter as yours. I had to deflate it and ratchet strap it to the rear bumper for it to clear the diff. But I didn’t have to bend the tabs that hold the spare in place. That said, I have Deaver springs, which move the rear axle back a bit, so YMMV.
  3. Feb 14, 2025 at 11:44 AM
    clenkeit
    Colin
    Lakewood, CA
    Oops, my bad I read that too quickly and thought it was a 255/80/17.
    I also had to modify my exhaust hanger. The 05-11 years have the rear hanger at a different angle which conflicts with a larger spare. I did all these mods to fit my 265/75R16 and it was tighter when fitting a 255/85R16 but still fit.
  4. Feb 14, 2025 at 12:22 PM
    RSM92
    RSM92 Active Member
    Robert
    2015 White Tacoma TRD Sport DCLB
    6112's w/ 5160's & OME Leafs, Sliders, Grill, Light Bar
    The 255/85/17 should actually be a full inch larger in diameter when compared to the 255/80/17 or 255/85/16 :thumbsup:
    TomHGZ[QUOTED] likes this.
  5. Feb 14, 2025 at 1:36 PM
    Pigpen
    Dan
    Northwest Montana
    This ^
