Fix costly repair or buy another truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomamitch, Sep 17, 2022.
  1. Sep 17, 2022 at 1:04 PM
    tacomamitch
    tacomamitch [OP] Member
    Seattle
    My Tacoma took a dive for the worst today. The dive that saddens all of hearts as truck owners. The flashing check engine light of death.
    I have 05 - 2.7TRFE with roughly 165k on it. I recently moved from across the state and went to start up my truck yesterday and this flashing check engine appears. I have traveled with the truck across country from Florida to TN, to now the west coast of WA. In all my moves nothing has ever gone array until finally reaching my destination on the other side of the country.
    I’m not the most mechanic savvy so I do a lot of DIY on my truck. Mainly from the helps of this site and YouTube. But When it comes to living in the city & engine issues I generally always get it fixed from a local shop that I trust.
    I brought my truck down to the nearest shop in the area for a diagnosis. They give me a call stating it’s reading 16 different codes, also saying theirs oil on my plugs, cracked pcr valves, and is hard to diagnose at this time. So they recommended a tune up spark plugs, coil packs, valve cover, clean fuel injectors, pcr valves, and a 2 year warranty for $2200.
    I tell them to proceed, until…
    The shop gives me another call saying I have a lot of play in my timing chain. There’s currently no noises or rattle from the chain but a good amount of play and is very loose. The shop quotes me $7500 for timing chain and tune up repair. The fellas at the shop do mention that it doesn’t necessarily need done now but will definitely need done down the road. Also that if I don’t do it not it could break and cause severe engine failure. Is this something I should tell them to replace?
    I probably have 8-$10k in value when the truck runs. $7500 is almost the whole value of the truck. Anyone else with 05 - 2.7 run into the timing chain issue? How much more mileage did you get out of the truck?
    or should I take the other route and use that 7.5K on a down payment for another truck?
    Any comments or help would be greatly appreciated as this situation has really put me in a pickle.
    John43 likes this.
  2. Sep 17, 2022 at 1:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    2,200 for a tune-up including valve cover gasket and coils? And then an extra 5,000 for a chain job? That sounds like waaay too much.
    When you originally brought it in, did they offer to diagnose it for free? If yes that is the first warning sign of a bad shop
  3. Sep 17, 2022 at 1:27 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Drop in a low mile used motor for $3k and be done, but take it to a shop that ain't got you by the short ones.
  4. Sep 17, 2022 at 1:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    20$ says they offer to buy it from him
  5. Sep 17, 2022 at 1:34 PM
    tacomamitch
    Seattle
    Yeah I just moved here so I will probably get a quote on another shop. I imagine it’s spendy everywhere as I’m in Seattle. But yes $7500 is with tax and all. $6850 w/o tax. Trust me I am not at all stoked on the situation. No they didn’t put an offer on the truck lol. Also $50 for diagnosis.
  6. Sep 17, 2022 at 1:44 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    IMO that's not enough. Heck that's not even 1/2 an hour labor. That low price gets you in the door and then they say "we can't even diagnose it, let's spend 2,200 and then see where we're at". No wonder they "can't diagnose it". By charging that little they're putting themselves is a postion where they couldn't even spend the time to diagnose it correctly even if they wanted to
    It's a bait and switch. I see it all the time. Now they've got your engine opened up and you're stuck.
    Sorry man. It's a shitty spot to be in. Honestly I'd be trying to get your truck out of there as quickly as possible
  7. Sep 17, 2022 at 1:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd get away from that shop $2200 for a tuneup and valve cover gaskets on a 2.7 is rediculous, it's like a 2.5 hr job at most.
    Timing chain R&R pays around 20hrs according to the Mitchell labor guide, they must be charging $200/hr + to come up with those figures.
    wilcam47 and Key-Rei like this.
  8. Sep 17, 2022 at 1:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That's the norm around here, I'm at 175$ per hour
    Bottom line, you can't spring that stuff on a guy halfway through a 2,200 job. If the chain was stretched there would have been timing related codes stored. Sounds like they didn't even try
    If I see ANY codes related to expensive problems, I'm bringing it up IN THE BEGINNING before any wrenches touch the car
  9. Sep 17, 2022 at 1:51 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Wow that's almost double the labor rates here, we are $80 and dealers are $100-120.
    davidstacoma and Geeves77 like this.
  10. Sep 17, 2022 at 2:06 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Same in Mass. about 100/125 hr
    Dealer prices
    Dm93 likes this.
  11. Sep 17, 2022 at 2:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    Only because you've not told them you're going to dump it yet.
    You need a second opinion.
    Tough spot to be in. Best of luck!
    whatstcp likes this.
  12. Sep 17, 2022 at 4:07 PM
    tacomamitch
    Seattle
    Yeah I’m SOL I’ll call around and get some different quotes. But I imagine I’m SOL, I’m thinking I put the money to a new truck. Right now I don’t think it’s worth it.
  13. Sep 17, 2022 at 4:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Stop, Mitch. Stop. Go to Anal Zone and buy the valve cover and spark plug tubes gasket kit for like $40 and install that. That’s all it needs. Trust me. Got mine installed for a hundo and with new plugs the truck is a rocket ship. Don’t give up just yet. Edit: so they had the valve cover off and didn’t replace the gaskets? Nice fuckers
  14. Sep 17, 2022 at 4:26 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Go somewhere else, or buy a good used engine, or buy a new truck.
    Good luck with whatever you do.
  15. Sep 17, 2022 at 4:35 PM
    saint277
    saint277 Vigilo Confido
    Someone can correct me if I'm wrong, but don't most timing chains have "a lot of play" when the tensioners don't have oil pressure?
    wilcam47 likes this.
  16. Sep 17, 2022 at 6:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I didn’t read the other guys answers.
    So I may be repeating what’s already said.
    Go to a different shop. Quick.
    That’s ridiculous, they’ve obviously pulled the valve cover by now to inspect the chain. (Or the valve cover gasket)
    So, you might as well let them do the valve cover gasket. And that should take care of the oil on the plugs. You can do the PCV, pass on that. Maybe let them do the plugs, since they probably pulled them anyways to remove the valve cover.
    Then, go to a different shop.
    whatstcp, SpanishTaco and Dm93 like this.
  17. Sep 18, 2022 at 6:08 AM
    Soulsurvives
    Soulsurvives Well-Known Member
    Bill
    2009 Tacoma
    I would avoid this shop for sure. Also go down and buy a code reader. They are less than 20 bucks at Walmart. Read your codes and then look them up. You will do much better being informed when going into a shop. Good luck.
  18. Sep 18, 2022 at 6:45 PM
    tacomamitch
    Seattle
    Yeah I’m gonna call around and get some different quotes on it Monday. But since I told them to proceed with the tune up don’t I have to honor what I agreed too in the first place or can I tell them not to work on it and just get everything back together as is and pay for whatever work they have done on it already.
  19. Sep 18, 2022 at 8:13 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    As long as they replace the valve cover and spark plug tube gaskets (and ask for the old ones back) sure, let them change the plugs
  20. Sep 19, 2022 at 6:58 AM
    wmgeorge
    wmgeorge Well-Known Member
    A timing chain should be good for the life of the truck, If the oil has been changed on schedule. Take it to another shop, this sounds like a rip off.
    NAAC3TACO likes this.
