FIX FOR P0031 P0051 P0037 P0057 P0430
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toytaco1, Apr 7, 2011.
  1. Apr 7, 2011 at 6:35 PM
    toytaco1
    toytaco1 [OP] Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    Thanks to TW I was able to fix these codes, if you have these codes come up at the same time and your truck isnt running right chances are your air fuel relay is bad and needs to be swapped out cost is 25 bucks
  2. Apr 7, 2011 at 6:38 PM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    Sub for future reference. Thanks. :thumbsup:
  3. Apr 7, 2011 at 11:22 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    Since i got my Doug Thorley shorty headers installed i got the p0430 code.
    Howd you fix your p0430?ive already had disconnected my battery overnight and tightened the gas cap. ive had 2 different mechanics look for an air leak,there isnt an air leak. My tacoma has 84,780 miles,so i hope its not the cat. Any suggestions would help! Thanks in advance
  4. Apr 8, 2011 at 4:18 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Where IS the air fuel relay?
  5. Apr 8, 2011 at 6:00 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Thanks! now I can file this one away for future reference....
  6. Apr 8, 2011 at 11:02 AM
    toytaco1
    jed
    moreno valley
    Yeah a quick test is to pull your fog relay and switch it with your air fuel heater relay because they are the same, if it works great if not check the sensor in front of the cats or check for a leak. When did it throw the code? how many miles after you installed your headers?
  7. Apr 8, 2011 at 1:40 PM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    less than 150mi
  8. Oct 16, 2014 at 7:51 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    where are u Matt?
  9. Oct 17, 2014 at 2:35 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Yesterday my truck threw 5 codes:
    P0031
    P0037
    P0051
    P0057
    P0102
    Swapped out the fog relay with the A/F heater rely and all codes cleared.
    Thanks OP for this thread!! +1 rep to you my friend
  10. Jan 4, 2019 at 6:56 PM
    Lukealive530
    Lukealive530 Member
    Luke
    2014 Dopeass Tacoma
    I just got the P0031 and P0051 codes and I realized my heater was only working on HI. I figured it was a fuse or relay so I started putzing around with fuses and relays, and then the next morning my CEL and traction controls off light came on.
    After reading some forums it does seem like it's still a relay issue. But it's weird that it's such a common issue. Also my trucks fuse box is set up differently in that the fog relay and heater relay are not the same. Instead , the dimmer switch and heater relay are the only similar relays. Hopefully tomorrow I can swap them and have that fix the issue. But just curious if anymore research has surfaced with this issue pointing out a different culprit
  11. Apr 4, 2019 at 8:02 PM
    Nightmare38oh1
    Nightmare38oh1 Member
    Jake
    Salt Lake City
    07 Trd sport double cab long bed 4wd
    Pro comp level, 17x9 MB 11 with 265/70r17 bfg ko2
    I’m also battling this issue. Tried swapping the relays and it hasn’t seemed to work for me. Getting desperate I went ahead and did all 4 02 sensors as well (they were original so why not). Any other ideas why this might be happening? Is there a chassis ground somewhere ?
