Fix for Squeaking Clutch
Discussion in 'Technical Chat' started by hladun, Apr 9, 2013.
  1. Apr 9, 2013 at 9:53 AM
    hladun
    hladun [OP] Well-Known Member
    Alberta
    Tacoma
    I have made a modification that stopped the squeak on my 08 clutch.
    First the disclaimer. This will fix the squeak (noise) that stops when the clutch is slightly depressed. This will not cure a damaged TO bearing or transmission input tube, but I think it will prevent these failures from happening in the long run. If you do a lot of towing you might not want to do this because the fix reduces the clamp pressure of the clutch.
    You need to get a mid 90's clutch MASTER cylinder from an F150. Inside you'll find a spring and collar. Remove and disassemble your slave cylinder and replace the spring with the F150 spring and collar. The collar fits on the peg of the piston that had the Toyota spring on it. It will be a bit of a struggle to reinstall the slave cylinder because the spring pre-loads the TO bearing.
    The spring you need should be about 3" long, 5/8" ID with a rate of 5 to 7 lbs/in.
    Many other vehicles (my experience with Porsche, Jaguar, Volvo, Maserati, Alfa Romeo, and Ford) have pre-loaded TO bearings and I've never had squeak problems with their clutches. Bearings don't like to run lose and/or slipping.
  2. Jan 10, 2014 at 11:27 AM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
    Got video?
  3. Jan 10, 2014 at 11:41 AM
    hladun
    Alberta
    Tacoma
    No video, but when you get the Toyota slave cylinder apart it's pretty obvious.
    P.S. I did this about 2 years ago and to date no squeak and no problems.
  4. Jan 10, 2014 at 3:21 PM
    gearcruncher
    Canadain bumper technician
    I like your fix . Hope it lasts forever but i doubt it .
    Your spring upgrade shouldnt reduce plate loading . The release bearing is constant design meaning it always turns but your pressure plate is responsible for the clamping force between the friction disc and flywheel . unless the total travel of the release bearing has changed ?
    EDIT : After reading the FSM , I retract what I mentioned here as I wasnt aware at the time . Your fix will stop the noise for a short while but is it a true fix ?
    The release bearing is designed as NON constant . The Tacoma does not use a self adjusting clutch.
    As the clutch disc wears out , the fingers on the pressure plate move towards the release bearing . All you did here is make the bearing spin .
    Trust me , this is Toyotas problem for leaving the adjustability out of the 2nd gen clutch
    Feel free to pm me even if you dont trust me:D
    Powerwagon896 likes this.
  5. Jan 10, 2014 at 3:48 PM
    hladun
    Alberta
    Tacoma
    I'm not sure what you're trying to say here. The total travel of the release lever (release bearing) is unchanged. All that happens with the stronger spring is there is sufficient force on the release bearing to keep it turning with the pressure plate fingers without slipping/vibrating/chattering when the clutch is released (pedal up).
  6. Jun 21, 2014 at 2:39 PM
    hladun
    Alberta
    Tacoma
    Here's a picture of the fix. This is the slave cylinder and its internals. You replace the weaker spring (upper in photo) with a stronger one that I described (lower in photo). The Ford collar I talk about fits the new spring to the green piston. That's it problem solved!
  7. May 15, 2015 at 11:34 AM
    hladun
    Alberta
    Tacoma
    Better than ever. There is no noise and the clutch works fine. It sounds like the bearing has actually "settled in".
  8. Oct 3, 2015 at 5:21 PM
    skiomax
    skiomax Pro skier
    Ottawa, Ontario
    2013 Tacoma TDR Sport DC
    Extang cover Thule roof rack pop & Lock Short antena Weathertech floor liner TRD skid plate Leather Seat package
    just had my slave cylinder replace and was told the new one have better spring... wont take there word for it but it sure is working way better then before.
  9. Oct 3, 2015 at 10:25 PM
    hladun
    Alberta
    Tacoma
    Here's a thread that shows the newer, stronger spring https://www.tacomaworld.com/threads...-slave-cylinder-rebuild.387315/#post-10720419 I had emailed Toyota a year or two ago about the fix so maybe that's why they're finally doing it. Part number is about $13 but there are still people out there throwing away thousands on clutch/bearing replacements. There's actually a video that shows replacing everything but the guy won't take out the slave cylinder (and fix it) because he thinks he can't bleed it...go figure. You can actually see the new TOB vibrating and making noise in a clip towards the end of the video. (2006 Toyota Tacoma 4.0L X-Runner Clutch Installation)
  10. Oct 14, 2015 at 11:25 AM
    bigfro
    bigfro Well-Known Member
    Denver
    13 TRD Sport DCSB
    Billy 5100 @ 1.85 + shim on L for Taco Lean Icon AAL 3 pack w Rear Overload Removed
    Sorry Yes you guys are right its that fix I am talking about.
    There is a Toyota TSB for the slave. Its on this site, I have seen it somewhere.
    Although if your trans bellhousing is already scared up from a cracked TOB, then I would personally use the steel sleeve + Toyota's stronger spring, but the spring will prob fix it without the sleeve.
    Cheers!
  11. Oct 14, 2015 at 12:34 PM
    hladun
    Alberta
    Tacoma
    Searched this website and Googled and can't find the mythical TSB. If there is one I'd sure like to see it (like the TSB number perhaps)?
  12. Oct 14, 2015 at 12:40 PM
    bigfro
    Denver
    13 TRD Sport DCSB
  13. Oct 15, 2015 at 5:53 PM
    hladun
    Alberta
    Tacoma
    The TSB just lists old and new parts which is what you'd expect. I eventually found this post which has pictures of what might be the old and new parts (no part numbers to confirm) https://www.tacomaworld.com/threads/tsb-clutch-chirp-need-input.160167/ The TSB requires replacement of the clutch release cylinder which is the culprit in this saga and what I've always recommended. The pictures do show a longer release cylinder but the link also shows a shorter TOB which will tend to move the release fork forward. So does the new longer cylinder apply enough preload when the fork is moved forward? Maybe/possibly/probably? I'd want to make sure there is 5 to 10 lbs of preload on the fork whatever the configuration of parts is.
  14. Oct 16, 2015 at 8:12 AM
    bigfro
    Denver
    13 TRD Sport DCSB
    Yup i agree on all fronts. I wish I could go back after Toyota for my 05. I had 4 TOB in the thing before 50k miles and the TSB didn't come out till the engine mounts failed and collapsed into the frame.
    The 05' was a nightmare. Wheel Bearings at 60k, Frame failure at 105k, 4 TOB by 50k, Transmission failure of 3rd gear synchro (new transmission at 65k)....
    The 13' is so much better on all fronts....
    My 05 was built in Feb of 04 so it was one of the first ones... I will never purchase a first year Tacoma again. lesson learned.
  15. Nov 25, 2015 at 5:42 AM
    Sworthen16
    Sworthen16 Member
    Stevo
    08 DC SR5 MT 4.0
    What year and info do you look up for the ford slave cylinder. I'm looking to do this this weekend. Hlandun
  16. Nov 25, 2015 at 6:41 AM
    hladun
    Alberta
    Tacoma
    My F150 was a 95 but now I'd try the Toyota kit in the link in my post #9 above.
  17. Mar 22, 2016 at 5:30 AM
    Sworthen16
    Sworthen16 Member
    Stevo
    08 DC SR5 MT 4.0
    Sorry to bother again, but was it from a v8 or v6 f150 or does it matter? I'm still going to try and use this before my chirp appears constantly. Its only periodic when temp drops below 32 and above 94 at them moment.
  18. Mar 22, 2016 at 7:52 AM
    hladun
    Alberta
    Tacoma
    Mine was from a 302 V8. Don't know about V6's.
  19. Mar 31, 2016 at 2:49 AM
    Sworthen16
    Sworthen16 Member
    Stevo
    08 DC SR5 MT 4.0
    :broccoli::fingerscrossed:Sucess! Found the correct part and swapped the spings along with using the ford collar. The slave was a bit of a struggle to re install and bleed but it only took about 30 mins. The partial chirp has now deceased for a week with no return. Also on a side note, the "new" upgraded spring in the new Toyota slave are a exact match to the existing one with no poundage diff.
  20. Mar 31, 2016 at 8:53 AM
    hladun
    Alberta
    Tacoma
    Glad it worked. If you have to struggle a bit to get the slave cylinder in then you know you've got the right solution.
