Fixed- Brake Drums locking up after boat Launch fresh and salt
Discussion in 'Boating & Fishing' started by FishaRnekEd, Feb 22, 2019.
  1. Feb 22, 2019 at 6:42 AM
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    The day after my drums get submerged, they are seized up and i have to tap them with a hammer. I'm gonna open it up and maybe hit the parts with some fluid film. Anybody have a better idea? what exactly is locking up in there? shoes/drums were changed last year, so should'nt have much wear.
    wilcam47 likes this.
  2. Feb 22, 2019 at 11:00 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    maybe lube the pivot points on the drum with some waterproof lube? Got to find out what is binding up.
  3. Feb 22, 2019 at 11:02 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    How far are you driving before you park it after you dunk them? If you're not warming them up with some braking at all after dousing them then there may be moisture inside still that is letting the shoes bond to the drums overnight.
    12TRDTacoma likes this.
  4. Feb 22, 2019 at 11:07 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's highly likely that when your shoes were replaced they didnt lube the base plate of the drums where the shoes move over.
    Salt water is hellacious (is that even a word?) on metal. Especially unlubricated metal.
  5. Mar 1, 2019 at 3:58 PM
    FishaRnekEd
    New Orleans, LA
    I'm getting the boat out and driving 10-20 miles with some stop and go before i park it. It sits over night and is seizure up in the morning
  6. Mar 1, 2019 at 4:00 PM
    FishaRnekEd
    New Orleans, LA
    Do you think if i spray some fluid film in that spot, it will fix the problem?
  7. Mar 2, 2019 at 2:54 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No. The best solution is to pull it apart and properly inspect what needs lubing or replacement.
  8. Mar 4, 2019 at 6:12 AM
    FishaRnekEd
    New Orleans, LA
    Well, yes, the drum has to come off. LoL, how else would you lube anything in there?
  9. Mar 4, 2019 at 8:38 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It will require a grease type lubrication, preferably a high temperature lube, like the ones that are provided for oxygen sensor threads, not spray lubricant of any kind, as that will eventually dry up and you may experience the same thing again.
  10. Mar 4, 2019 at 9:22 AM
    FishaRnekEd
    New Orleans, LA
    12TRD, thanks.
    I use fluid film sometimes, it is a spray but it's good for leaving a thick stick lube coat in hard to reach places.
    I guess ill find something more suitable. I think i have a little packet of brake grease somewhere.
    12TRDTacoma and wilcam47 like this.
  11. Mar 4, 2019 at 1:02 PM
    wilcam47
    Will
    Bourbon state
    most parts stores or even walmart is going to have a waterproof grease for grease guns. Its usually blue/green colored, especially for marine purposes..
  12. Mar 7, 2019 at 10:15 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Maybe after you launch and retrieve the boat, drive around the marina area applying brakes to burn off/dry up the drums.
    I know I get sticky drums after I wash the truck if I don't drive around the block after washing.
    FishaRnekEd[OP] likes this.
  13. Mar 7, 2019 at 10:55 AM
    FishaRnekEd
    New Orleans, LA
    I actually tried that before. for whatever reason, it still happens. ill report back after i open up the drum.
  14. May 1, 2019 at 4:43 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Fluid film will burn off after the first stop.
  15. Sep 20, 2022 at 5:34 AM
    FishaRnekEd
    New Orleans, LA
    THE FIX
    this was a few years ago. here is what i tried.
    i removed the drum and put high temp brake grease on the mating surfaces. (except the braking surface of course)
    it still happened after a few launches.
    the salt water just made the grease into a mess and glazed the shoe pad/drum.
    i removed drum, cleaned/sanded and applied marine grease. same thing happened after a few launches.
    after a while, they got stuck so bad that i had to hammer the drum, after backing off the adjuster. then i had to drag the truck with the front end in 4Lo to concrete and rock the tranny back and forth to break them loose.
    when i got home i found that the bottom springs WERE COMPLETELY GONE. The saltwater ate them after a few months. without the bottom shoe spring, one of the tips of a shoe actually bent and was touching the vertical side of the drum.
    i replaced the shoes and all the springs.
    i didn't put any grease this time
    i drilled a hole in the bottom of the back plate between the bottom end of the shoes as low as possible. i plugged the hole with a rubber cap.
    when i get home after a launch (while I'm flushing the boat motor) i remove the rubber cap on top for the adjustor and remove the bottom cap that i made. then i SPRAY brake cleaner TO FLUSH OUT.
    HAVE NOT HAD A PROBLEM SINCE
    it's been about ten launches.
    this costs a can of brake cleaner every time i launch
  16. Sep 20, 2022 at 5:39 AM
    FishaRnekEd
    New Orleans, LA
    i plan on converting to discs eventually, but replacing the springs is like $20 and the shoes are not worn much.
    rear disc kits aren't cheap and some don't even have a parking brake.
