Fixed more vibes! For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd09, Jan 28, 2011.
  1. Jan 28, 2011 at 9:28 PM
    trd09
    trd09 [OP] Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Have the TSB and 5100s at 2.5. Had a little takeoff shudder and vibe around 20-30 mph then 40 or so.
    I installed carrier bearing spacers (thread
    After about a year or so, I figured I'd tinker with it more because the back end settled a little bit and I still had a few vibes in the same speed range.
    I removed one of the washers (so I have four now) and then I was thinking, how does the alignment of the carrier bearing effect vibes?
    I tightened it up without making note of alignment and took it for a test ride. Vibes were back bigtime!
    Loosened it, then centered the carrier bearing according to pg. 2 of the linked FSM (link).
    Vibes almost gone!
    I'm going to try to get it 100% perfect tomorrow.
  2. Jan 29, 2011 at 4:43 PM
    Sportsphreek
    Sportsphreek Active Member
    Virginia
    Double Cab TRD Off Road
    Thank you SO MUCH for this information. When I bring the truck in on Monday, I'm going to try and get Toyota to do it for free since technically their TSB Leaf Springs caused the problem.
    Keep us up to date on what ends up working out best for you.
    -Kevin
  3. Jan 29, 2011 at 11:09 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Made a small adjustment today when it came to centering the carrier bearing using the drain hole (according to the FSM)
    My vibes between 20-30 are almost completely gone. Most of the time I can't feel them. Only ones left are a little vibesw around 35-40 but not bad at all.
    So happy to make some progess!
  4. Jan 29, 2011 at 11:17 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  5. Jan 30, 2011 at 11:58 AM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2010 2.7 4x4 AC
    So did you find that the carrier bearing wasn't lined up or are you just adjusting it a little and doing a test ride?
    Thanks,
    Ron
  6. Jan 30, 2011 at 10:06 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    The carrier wasn't aligned properly when it was stock.....
    Update: lined it up as well as I could and alas, take off shudder is 90% gone (the rest is prob axle wrap) and the 20-30mph vibes are GONE!
    The lingering vibes between 30-40 have been tougher to notice, but they always are, and they felt like something in the front end. I'll try to update later.....
    In short, CHECK YOUR CARRIER BEARING!!!! Takes less than a minute to adjust with a 14 metric wrench.
  7. Mar 6, 2011 at 5:20 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i also have pulsating vibe from 30-40 mph and i'm positive its my driveshaft. I found out the same way you did by removing spacers on the CB and when i retightened no spacers it made the vibe 50% better than before. I did not pay attention to the alignment of it, but are you saying that it just needs to be as seen in page 2 with the tabs on the side where the bolts go through to be exactly (or close to) 90 degrees with the shaft?
  8. Mar 6, 2011 at 5:26 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    yes. mine were not close to being aligned. if yours are close it shouldn't make too much difference.
    fwiw, i have the 30-40 vibe that is actually noticeable, but it goes away in 4wd. pretty well documented problem at this point. if your vibe goes away in 4wd than it's the front diff....
  9. Mar 6, 2011 at 5:52 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    This is the opposite of the correct use of alas. Did you mean voilà? :D
  10. Mar 6, 2011 at 6:45 PM
    TacomaGus
    Gus
    Morgantown, WV
    no it remains in 4wd unfortunately. I noticed while driving on the highway that the vibe was the same in certain instances around 60-65 when i was trying to climb a hill in 5th and the same pulsating vibe (not a balance "shake") would occur, but once i downshifted to gain some rpms it would stop. So that also makes me believe its the driveshaft. I'm still gonna do your suggestion tomorrow and see if i can get the CB bracket as close to 90 degrees with the DS as i can, since when i did tighten it up last time it did affect the vibes in a positive way so we'll see.
    Prob just gonna have to go with a one-piece DS or find one in the junk yard that isn't shot. Or maybe just replace my carrier bearing? my u-joints are fine
  11. Mar 6, 2011 at 6:57 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    haha, thank you
