Fixed my 2012 driver door "Window Rattle"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doorsidedown, Sep 2, 2014.
  1. Sep 2, 2014 at 8:01 AM
    doorsidedown
    doorsidedown [OP] Well-Known Member
    All,
    I have a 2012 DCSB and my drivers side door window would rattle anytime I shut the door. It drove me nuts to the point that I decided to remove the door panel and take a look around. It seems the "bolt fix" for the first gens has been moved underneath the door panel for the second gens. I'm not saying this will fix everyone's problem - but hey, one can hope!
    I've attached a picture that will show my loose bolt. I also made sure all the other bolts were tight since i had the panel off, but once i tightened this down, no more rattle!
    Here's a good video to help you remove the door panel:
    http://youtu.be/h9pHl9Co_38
    I do not know these guys - so use this video at your own risk...
    Good Luck!
  2. Sep 2, 2014 at 12:24 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Um...I prefer this video...
    http://youtu.be/yjhYKzE_yBg
    But your post is good...I had to fix my 06 a few years back with the same issue.
  3. Sep 2, 2014 at 1:27 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    so you tighten that bolt you pointed at or what?
  4. Sep 2, 2014 at 2:22 PM
    09TRDSpt
    09TRDSpt African Light Infantry
    Atlanta, GA
    09 TRD Sport DC 4x4
    Mine does the same thing, kind of a tuning fork effect. I'll have to pull the panel now :).
  5. Sep 2, 2014 at 3:00 PM
    doorsidedown
    Yes. just tighten the bolt. I don't have any torque specs for you, but mine was loose enough that I tightened it up with my hand before wrenching on it a bit.
  6. Sep 2, 2014 at 3:01 PM
    doorsidedown
    For some reason, this video is slightly more informative. haha.
  7. Sep 2, 2014 at 7:36 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    subbing
  8. Sep 2, 2014 at 7:54 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Yeah I agree, I'm more of a visual type of guy :D
