Fixed my cracked grille surround
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kreitzmtaco, Jan 29, 2018.
  1. Jan 29, 2018 at 7:51 AM
    Kreitzmtaco
    Kreitzmtaco [OP] Well-Known Member
    Canton, Ohio
    17 Taco TRD OR/DCSB, Prem & Tech, JBL,& Tow
    I fell victim to the dreaded cracked grille surround due to the combo of cold Temps and the BAMF grille.
    I looked at the cost of a new surround and thought I would try to fix this one before shelling out hundreds of bucks. So, I took off the surround and removed the BAMF grille.
    I was thinking that since the crack was such a clean break that I might be able to epoxy it together again. I looked around for some plastic epoxy and settled on this:
    Because it said it could bind all plastics and I wasn't sure what kind of plastic the grille surround was. I cleaned all surfaces with acetone and proceeded to apply the activator and glue. 20180127_133337.jpg20180127_133544.jpg
    After holding them together for 45 seconds this is what I had:
    I thought "not bad, will look ok after I clean it up." But, I wanted it to have more strength so I decided to reinforce it with the fiberglass kit BAMF suggested on its website:
    Once again I cleaned everything with acetone. I then cut up some fiberglass strips and mixed the resin together. I applied the 4 strips and resin and let it sit overnight.
    The next morning I cleaned it up and put it back together. I think it looks pretty good. Unless it is in the right light, and you know what to look for, most people wouldn't even see it.
    I bought a Pro grille to replace the BAMF because I am not sure the repair would stand up to the BAMF.
    ETA: don't mind all the dog hair from my pug. I did this in my basement workout room and hadn't swept it in a while. I vacuumed it all up after since I had fiberglass fibers everywhere.
  2. Jan 29, 2018 at 8:04 AM
    Taco16LB
    Taco16LB Well-Known Member
    Very nice work !
    Kreitzmtaco[OP] and ChadsPride like this.
  3. Jan 29, 2018 at 8:06 AM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Looks great! I was wondering what all the fuss was about since most people had such a clean fracture that making it look almost like new shouldn't be that hard and this proves it.
    Better alternative to buying a whole new piece. Although this fix could mean that if you keep the grill, next winter it would hopd up or the crack would move on to the next stress point(opposite side or somewhere else)
    Kreitzmtaco[OP] likes this.
  4. Jan 29, 2018 at 8:06 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Wow, that looks good!
  5. Jan 29, 2018 at 8:07 AM
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    Very decent repair job. What about prophylactically reinforcing the opposite side now? Some owners have had the fracture on the passenger side, others driver's side. Just curious if now your passenger side could crack.
    (looks like 3 of us were all posting simultaneously)
    Edit--Okay, so 4 then.....I do see now that OP has installed a different grill than the BAMF; prophylactic reinforcement of the opposite corner is moot, however, others with the BAMF grill could consider pulling off their shroud and doing your fiberglass reinforcement mod if they live in cold climates. Interestingly, I have not seen any of these BAMF grills out here in HI
  6. Jan 29, 2018 at 8:08 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Wonder if it would be wise just to lay some resin in the other side to help prevent a crack?
    Kreitzmtaco[OP] and Taco16LB like this.
  7. Jan 29, 2018 at 8:09 AM
    Zimn8r
    Zimn8r Well-Known Member
    2017 TRDOR DCLB BBP
    Was hoping you'd come up with a way to fix it and keep the BAMF, but I know that's a lot to hope for.
  8. Jan 29, 2018 at 8:10 AM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Nice work! I just noticed you even had the eco grill. I thought it was just the recessed one that was causing the problems.
  9. Jan 29, 2018 at 8:11 AM
    marjamr
    marjamr Well-Known Member
    Mark
    2017 Silver Tacoma SR
    Western Defender snow plow
    Good job! Nobody will ever notice that.
  10. Jan 29, 2018 at 8:14 AM
    Kreitzmtaco
    Canton, Ohio
    I thought about reinforcing the other side but decided not to since I am not putting the BAMF back on. I went ahead and bought a Pro grille from Amazon for $150. I figure with the flexibility of the plastic of the Pro grille I should be safe without reinforcing the other side.
    I am going to be selling the BAMF grille to recover the costs of this repair.
    shakerhood and Taco16LB like this.
  11. Jan 29, 2018 at 8:24 AM
    Kreitzmtaco
    Canton, Ohio
    You could always try this and reinforce the whole grille surround to put the BAMF back in. The fiberglass kit was only $27 on Amazon and there is plenty of it to do the whole grille. I just didn't do it because I knew I was replacing the BAMF.
  12. Jan 29, 2018 at 8:44 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    sorry to see the crack. on ours I never really cranked down on the screws and it survived 2 brutal -20F winters up here without cracking.
  13. Jan 29, 2018 at 8:47 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Wouldn’t the dealer cover that if you are still under factory warranty?
  14. Jan 29, 2018 at 8:49 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    I love the BAMF grills but I was unaware that they eventually crack the surround?? Has this been the case with many others?
  15. Jan 29, 2018 at 8:51 AM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Has anyone tried to trim the metal grill all the way around and then re-installing it??? Or at least in the areas where the surrounds are cracking?? Grinder/cutoff wheel etc.
    Or is that impossible to fitment tolerances??
    over60 likes this.
  16. Jan 29, 2018 at 8:59 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Uh, no not when you put an aftermarket grille in.
  17. Jan 29, 2018 at 9:01 AM
    Kreitzmtaco
    Canton, Ohio
    I don't think they would, I didn't even try, I am sure they would say it was due to excessive pressure from the BAMF grille (which is a very tight fit) and not because the surround was defective.
  18. Jan 29, 2018 at 9:05 AM
    Kreitzmtaco
    Canton, Ohio
    I thought that might have been what I did but when I took it apart the bolts weren't very tight at all. It didn't crack until we got to - 18 or so. I know the exact day it happened because I checked it every morning in my garage because I was worried it would happen. It was fine last winter but it didn't get that cold then.
  19. Jan 29, 2018 at 9:06 AM
    Zimn8r
    2017 TRDOR DCLB BBP
    SC, you're probably fine. Mine broke when it was -8 and had been -13 or so the day before.
    PvilleJohn[QUOTED] likes this.
  20. Jan 29, 2018 at 9:06 AM
    Kreitzmtaco
    Canton, Ohio
    I never thought of that. I bet it would work because I think the tight tolerances were the main cause.
    over60 likes this.
