[FIXED] Vibrations started immediately after lifting (2018 DCOR - Bilstein 6112 + 5160)
Discussion in 'Suspension' started by ashakespeare, Dec 16, 2018.
  1. Dec 23, 2018 at 3:02 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Get the angle at the rear axle flange, and at the CB and add that to your sketch.
    Just like in that video posted earlier, once you have those numbers you'll have your answer. :)
    TXpro4X4 likes this.
  2. Dec 24, 2018 at 9:35 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    So if I understand correctly he was/is lifted to high for the drive tran and the drive shaft was being extended and causing the vibration?
    Assuming he is to high
  3. Dec 24, 2018 at 12:05 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    In his case and in by the looks of it, in your case also,
    dropping the CB messes up the angle to the transfer case, he was going to use angled shims to rotate the angle of the rear axle.
  4. Jan 16, 2019 at 5:57 AM
    phoenixpiole
    phoenixpiole Well-Known Member
    2018 Tacoma DCSB SR5
    I think I’m also having this issue, all of the symptoms are the same after installing a 2” ARB OME old man emu lift kit on my truck.
    Going to try 3 degree shims on the rear axle and removing the spacers on the CB, hopefully that will fix the issue.
    Does anyone know if these type of vibrations will cause damage to the differential or transmission if left unchecked short term?
  5. Jan 18, 2019 at 3:10 PM
    ashakespeare
    ashakespeare [OP] Well-Known Member
    2018 DC TRD OR
    Hello TW. Thank you all for your help. The vibrations are gone after following your advice.
    Remedy:
    • Installed 1/2 carrier bearing drop - still had vibrations
    • Installed 2.5 degree shims on the rear axle - VIBRATIONS GONE!
    Hard to say if it would be good with just the shims and no CB drop, but I'm not messing with it anymore ;)
  6. Jan 24, 2019 at 1:38 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    who did you get the shims from? mount between the axel flat plate and the bottom of the leaf spring - skinny side forward?
  7. Jan 24, 2019 at 7:05 PM
    ashakespeare
    2018 DC TRD OR
    My mechanic brought them in, but they are ProComp 99-250B. Correct - they go under the leaf pack, thin end forward, to make angle A in my diagram above closer to matching angle B.
    GoldenBrew[QUOTED] likes this.
  8. Jan 25, 2019 at 5:32 AM
    Nockturno
    Nockturno Well-Known Member
    2017 MGM Tacoma TRD Sport, DCSB, 6MT
    I just installed my suspension as well. HD Dakar OME installed, and I also start noticing a slight vibration when slowing down and/or speeding up. At first I thought it was something I did during the install, but I did get the alignment done at 4x4 specialty shop, and they did not a problem with the install once aligned.
    ^ I am also curious to know the same thing as to how much damage it can potentially cause if left unchecked.
    Do you mind showing a picture of how the shim is installed. I haven't done any angle measurement, but sounds like the same issues I currently have.
  9. Jan 26, 2019 at 4:59 PM
    ashakespeare
    2018 DC TRD OR
    3 different mechanics told me that a small amount of vibration will not be problematic. I think it's more a quality of driving thing.
    This isn't my photo, but is exactly like mine is setup. 3* shims, on top of axle, underneath the leaf pack, with the thin end towards the front of the vehicle. https://twstatic.net/attachments/image-jpg.985429/
    Nockturno[QUOTED] likes this.
  10. Jan 26, 2019 at 5:14 PM
    Nockturno
    Solid. The vibration can get annoying after a bit, looks like I will be doing the same.
  11. Jan 26, 2019 at 7:27 PM
    ashakespeare
    2018 DC TRD OR
    Agreed. It wasn't major but annoyed me enough to fix it.
  12. Feb 1, 2019 at 3:29 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    holy hell am i glad i found this thread. had been having same vibration after installing my lift. neglected to install the CB spacer, didnt think it would make that much difference. will slap it in and add some angle shims.
  13. Apr 12, 2019 at 1:22 AM
    Vjtrey1
    Vjtrey1 Well-Known Member
    Richmond, Tx
    2018 Super White Tacoma TRD OR DCSB
    Simple mods
    What degree of shim for medium dakar leaf pack?
  14. Apr 12, 2019 at 4:03 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
  15. Apr 12, 2019 at 8:27 AM
    #35
    ashakespeare
    2018 DC TRD OR
    The general consensus is 1* per inch of lift. However, the real way to tell is by measuring your driveline angles. Read through the previous posts to see how with a cheap inclinometer off Amazon. For me, the general rule was correct - 2.5* shim and CB drop fixed the vibrations after a 2" lift.
    Fullsendcf likes this.
  16. Apr 13, 2019 at 2:08 AM
    #36
    Vjtrey1
    Richmond, Tx
    Simple mods
    Just an update I fixed my all vibs or shudder gone specially on deceleration I did installed 3 degree axle shims.
    whatstcp likes this.
