***Fixed
Discussion in 'Technical Chat' started by kayakingguy, Jun 24, 2017.
  1. Jun 24, 2017 at 3:16 PM
    kayakingguy
    kayakingguy [OP] Ask about my custom truck detailing!
    OutsidaTampa
    FIxed: with new water pump and flush is not overheating
  2. Jun 24, 2017 at 4:59 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You might have a bad head gasket. Have you done a compression check yet?
  3. Jun 24, 2017 at 5:01 PM
    kayakingguy
    OutsidaTampa
    Nope. Need to get a kit to do it.
  4. Jun 24, 2017 at 5:08 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    What vehicle are we talking about?
    I would check the radiator cap and pressurize the cooling system to be 100% certain you don't have a coolant leak.
    Does this vehicle have a fan clutch? Is your fan belt tight?
    MrCrowntown likes this.
  5. Jun 24, 2017 at 5:26 PM
    kayakingguy
    OutsidaTampa
    96 2.7 manual 4X4, Fan RPM is good and I checked the belt tightness when I replaced the water pump. There's no external coolant leak so as you said; need to do a pressure test to see if head gasket or something is cracked.
  6. Jun 24, 2017 at 6:07 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Had this on my Honda civic: oil in the coolant, bubbles when the radiator cap was off and overheating. It ended up being a cracked block. Like others mentioned do a pressure check and inspect the coolant for contamination.
  7. Jun 24, 2017 at 6:12 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    As stated check for head gasket, also don't be convinced fan clutch is good just cause fan turns. I chased a fan clutch for a month. Was a bitch
