Fixin to Pull my 6-speed manual and replace everything Need opinions Guys!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TNyota19, Oct 17, 2017.
  1. Oct 17, 2017 at 9:19 AM
    TNyota19
    TNyota19 [OP] New Member
    hagen
    2013 Tacoma 6-Speed
    none
    Hey everyone,
    Ive got a 2013 with 124k. I had my throwout bearing replaced around 99k and its making noise again that I can hear in cab a little. No Chirping outside yet like last time. Ive got 2k to spend on parts ad enough to cover Labor already set aside. I want no issues for another 100k. what would yalls plan of Action be???
  2. Oct 17, 2017 at 10:32 AM
    81shark
    81shark Well-Known Member
    i guess if i had to crack mine open, i would do everything from the fly wheel to clutch to throwing out bearing.. maybe even toss in a new slave cylinder. pretty much all that is in there...
  3. Oct 17, 2017 at 10:36 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Consider having the urd quill sleeve and oversized tob installed at the same time to prevent possible problems in the future. While your in there.
  4. Oct 18, 2017 at 6:58 AM
    TNyota19
    hagen
    2013 Tacoma 6-Speed
    none
    I am def replacing the Flywheel and Clutch. Im thinking of going with just the Stage II URD and Lightweight Flywheel and The hydro Sleeve deal and oversized Bearing put in. Hopefully that will keep her running for along time with no issues
  5. Oct 18, 2017 at 7:03 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I would avoid a light weight flywheel on a truck. Especially the big V6 we have. You want that extra mass to keep things smooth and it will help keep momentum and torque offroad too.
  6. Oct 18, 2017 at 7:10 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I would also replace the rear main seal and associated oil seals in the rear. Hate to have them leak soon after replacement of the clutch because all that labor will have to be done again. Plus oil on any friction material like clutches and brakes kills them. That is SOP for me.
    Key-Rei likes this.
