FJ case in a 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacotacochaquito, Oct 6, 2018.
  1. Oct 27, 2018 at 8:14 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    How did you set up the center console?
  2. Oct 27, 2018 at 8:57 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Impressive mod, truely (not being sarcastic).
    (Just saying, there are easier ways to get 2 wheel low, which i agree is pretty cool, not that you did the mod for 2 wheel low)
  3. Oct 27, 2018 at 9:22 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Pics?
  4. Oct 28, 2018 at 2:35 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
  5. Oct 28, 2018 at 4:51 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Nice work.
    Can we get a picture of that driveway?
    Hofmann’s Tacos, SR-71A and hirod like this.
  6. Oct 28, 2018 at 4:53 AM
    jowybyo
    Joe
    Baltimore, MD
    Since you have an FJ case you had 2low without twin sticks. Just shift into 4Low but don’t actuate the front diff and you’re in 2Low. No twin stick necessary.
    Tocamo likes this.
  7. Oct 28, 2018 at 6:10 AM
    tacotacochaquito
    tacotacochaquito [OP] Active Member
    Brian
    17 taco
    Toytec boss Full rci skids Archive off-road shackle mounts Dirty5s
    Well I locked the front diff because I haven’t figured out the computers yet. So the front is locked it. I’m probably going to keep it that way and just trick the computer into thinking it is in 2hi so my dash stops flashing like an airport runway.
    I haven’t modded the center console yet because I’m waiting on a taco box which will shift my levers back so I don’t want to ruin the console yet
  8. Oct 28, 2018 at 6:12 AM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
  9. Oct 28, 2018 at 5:42 PM
    tacotacochaquito
    Brian
    17 taco
    Also the driveway is just really steep and gravel. The 35s are hard to spin with a manual trans
  10. Oct 28, 2018 at 6:07 PM
    BigWhiteTRD
    Ted
    Just for your info, pretty sure to jump the ADD wires so truck thinks it is in 2wheel drive always:
    5 ohm across pins 1 and 2 (recommend power resistor in case power gets inadvertently applied to the actuator)
    Jump Pin 3 and 5 to Ground (pin 4)
    Don't hold me to this 100%, because it has been months since I have messed with it, but pretty sure.
    Pin numbers are at the 6 pin connector at the ADD. Can also do this at the 8 pin connector near the ADD, or at the ECU (different pin #s at these locations)
  11. Oct 29, 2018 at 8:42 PM
    tacotacochaquito
    Brian
    17 taco
    Woah. Thanks a ton man.
    Any way to do anytime locker?
  12. Oct 30, 2018 at 8:12 AM
    BigWhiteTRD
    Ted
    First I should mention that I assume you have to do similar for the transfer case actuator, otherwise it will cause all the same failure lights. I wasnt sure if you left the transfer actuator just hanging...
    Anytime locker has been worked extensively, but never actually tested/implemented. See
    https://www.tacomaworld.com/threads/rear-diff-lock-anytime-mod-3rd-gen-development.537810/
    I dont super care about the anytime lock mod, so I haven't built a plug and play module for testing yet. That mod was intended to manually send voltage to the diff lock and cause it to lock. You can build one if you want, similar to the schematic in the dev thread, and I can help if that is the route you want to go. This would not be my suggestion.
    I think you need to take a different approach from anytimelock. Instead call this anytime fake 4lo. This idea would be possibly just slightly more effort to activate in the cabin, but would keep Atrac or MTS/CC.
    If it were I, i would leave the ECU in control of the rear diff. I would electrically replace both the ADD and transfer actuator each with a resistor and a multi-pole relay. Add a new switch to the dash, (or more difficult and add this to the existing dash control, but doable).
    New switch, when operated, makes truck think you are in 4Lo. Here would be the sequence. Driving truck doing whatever you want, 2Lo, 4Hi, etc. You want either ATrac/MTS or rear lock. Stop moving, Throw your added switch into 4Lo mode, then turn dial to 4Lo. Truck will instantly think you are in 4lo and will allow rear locker, ATrac/MTS/CC. Use as you wish. Auto tranny will be in 4Lo shift pattern.
    When done with 4lo, turn off your added switch and turn dial to 2hi on dash. Truck will instantly accept that you are in 2hi.
    That is actually electrically easier than wiring up anytime diff lock, and keeps added functionality of atrac/mts/cc.
    I can help you with a schematic for this if you want to try. (I already did almost exactly this on the front ADD as part of 2wheel low mod). Just have to do it on the transfer actuator. Bet we can come up with a schematic for it in an hour or two. The only thing I dont know to do this method right now is resistance of the transfer case actuator motor to fake out the ECU. (It might be in the repair manual, or just bust out ohmmeter)
    SR-71A likes this.
  13. Oct 30, 2018 at 8:42 AM
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    Damn, this thread is gonna be legendary!
    mikestaco17 likes this.
  14. Jan 3, 2019 at 9:01 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Well I got here from here
    https://www.tacomaworld.com/threads/fj-t-case-into-a-3rd-gen.582029/
    Did you finish this and/or get further along? Any finishing pics or info?
    A couple months ago I was reading this and just curious.
    Very involved courageous modification.
  15. Jan 3, 2019 at 9:14 PM
    #35
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Wow, this makes me miss the simplicity of my 93 pathy mt. A lockright lunchbox locker in the rear and Warn premuim hubs up front and 2wLo and pretty capable.....250k rusted & welded frame called it's number.
    @tacotacochaquito ...Did marlin crawler have any options??
  16. Feb 24, 2019 at 5:26 PM
    #36
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Can anyone confirm the spline count on the input shaft? All my research shows 23 spline but I’m trying to confirm for sure before I drop money on an Atlas t-case.
  17. Feb 25, 2019 at 5:08 AM
    #37
    KiteGuam
    KiteGuam The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
  18. Mar 26, 2019 at 11:25 AM
    #38
    Toyotafanforlife1991
    Toyotafanforlife1991 Live FREE and drive a TOYOTA!!!
    Brandon
    Dickson, Tennessee
    2016 QS Tacoma DCSB OR M/T, 1970 Toyota Land Cruiser FJ40 351W M/T, 1982 Toyota Hilux SR5 M/T, 1983 Toyota Hilux SR5 M/T (undergoing frame off restoration)
    This is a screenshot from Marlin crawlers 2016 6 speed M/T build. He shows the 3RD gen Tacoma 6 speed M/T has a 19 spline input shaft and the auto 6 speed has a 23 spline input. So he swapped the input gears from an auto 23 spline into his 6 speed M/T(replacing his factory 19 spline input), so he can run his Marlin dual cases in his 3rd Gen Tacoma. Below is a link to his build, he has done some pretty badass work for is 3rd gen owners. Hope this helps!
    https://board.marlincrawler.com/index.php?topic=100408.msg1141889#msg1141889
  19. Mar 26, 2019 at 11:36 AM
    #39
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    how could they tell you offroaded it?
    Tocamo likes this.
  20. Mar 26, 2019 at 11:48 AM
    #40
    CheapLaborTJ
    CheapLaborTJ Well-Known Member
    What an incredible business model and marketing machine. Selling mid sized under engineered and overpriced trucks to the U.S. posers and mass market who think they can climb mountains with these trucks.
    Front sight likes this.
