FJ case in Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Usethe2nd, Jul 26, 2016.
  1. Sep 14, 2016 at 7:13 PM
    #41
    Usethe2nd
    Usethe2nd [OP] Well-Known Member
    Justin
    Fall city
    Welded metal
  2. Sep 15, 2016 at 2:22 AM
    #42
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I used the switched you purchased. I also wired it to use the limit switched in the actuator. Works fine. You should be good.
  3. Sep 15, 2016 at 7:52 AM
    #43
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Do you have a diagram of how you wired yours?
  4. Sep 15, 2016 at 1:44 PM
    #44
    Usethe2nd
    Justin
    Fall city
    Welded metal
    The up function will be 4x4 engaged
  5. Sep 15, 2016 at 3:42 PM
    #45
    jowybyo
    Joe
    Baltimore, MD
  6. Sep 15, 2016 at 3:45 PM
    #46
    Usethe2nd
    Justin
    Fall city
    Welded metal
  7. Sep 15, 2016 at 3:52 PM
    #47
    jowybyo
    Joe
    Baltimore, MD
    Just hold your switch upside down when you wire it
    Usethe2nd[QUOTED][OP] likes this.
  8. Sep 15, 2016 at 7:51 PM
    #48
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Could someone double check this?
  9. Sep 16, 2016 at 1:12 AM
    #49
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    What is the benefit of swapping for an FJ case?
  10. Sep 16, 2016 at 1:53 AM
    #50
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    With this, what is done with the original 4x4 H2-H4-L4 switch?
  11. Sep 16, 2016 at 5:14 AM
    #51
    jowybyo
    Joe
    Baltimore, MD
    Less electronics. The FJ case is a manual stick shift transfer case.
  12. Sep 16, 2016 at 5:23 AM
    #52
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    You eliminate the t-case shift motor but still have to trick the front diff disconnect. I wish Toyota still offered manual hubs, too.
    Also I think you get a neutral position, which can be handy.
  13. Sep 16, 2016 at 8:16 AM
    #53
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    D - all of the above.
  14. Sep 16, 2016 at 8:50 AM
    #54
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Also get 2 Low
  15. Sep 16, 2016 at 12:43 PM
    #55
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Switch works! Just have to make sure it functions correctly, sticks are sitting on the porch!
