fj cruiser owner needs help with 4.0L (pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by makim, Jun 9, 2010.
  1. Jun 9, 2010 at 9:57 AM
    makim
    makim [OP] Well-Known Member
    Poland
  2. Jun 9, 2010 at 9:58 AM
    night_angel
    night_angel Well-Known Member
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    ECU FT500, JBA Headers, 100% Offroad
    check the Ignition Coil`s, and check you Spark Plug`s...
  3. Jun 9, 2010 at 10:15 AM
    LaTeM
    LaTeM Everyday Trollin'
    MeTaL
    Jersey Shore, NJ!!!
    '10 4X4 Lifted 4Dr Pre-X-Runner
    LOL, nice I was thinking of taking one to Portugal! :D
  4. Jun 9, 2010 at 10:26 AM
    makim
    they are super rare here, nothing like it here ;)
  5. Jun 9, 2010 at 11:33 AM
    Brandon###
    Brandon### Well-Known Member
    The plug doesn't look that bad to me. Id just put a new set of plugs in keep a close eye on the oil level. I can't see how reving it up a few times would hurt anything. Its normal for vehicles to use some oil between oil changes too.
  6. Jun 9, 2010 at 11:46 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    Is there blue smoke coming out the exhaust? Usually that's a sign an engine is burning oil. Even that doesn't necessarily cause a significant loss in power. I've got a mustang with bad valve seals that makes a ton of power.
  7. Jun 9, 2010 at 12:21 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    OP. rev'ed to what? was he in neutral and he let the motor rev up unbridled? if so, you risk bent valves. i was in track car when this happened..missed shift, RPM went to the moon..but just once. after that, there was a mild loss of power and a barely percievable motor vibe.
    leak down and compression test time.. found bent valves...good luck.
  8. Jun 9, 2010 at 12:26 PM
    makim
    yup the car was in park, he reved up to 5500rpm or so, rev limiter kicked it
    as far as bent valves, I guess it depends on an engine
  9. Jun 9, 2010 at 12:27 PM
    makim
    no smoke, a very small mist when I start it up, but it only lasts for few seconds, probably water vapor in the exhaust.
  10. Jun 9, 2010 at 12:53 PM
    BeerHat
    BeerHat Got Beer?
    TX
    2001 PreRunner 4x4
    PreRunner 4x4, Homebrew Front Bumper, Homebrew Sliders, Homebrew Skids, Homebrew Bedbar, Homebrew Beer
    Hope this helps:
    from this: http://www.gnttype.org/techarea/engine/plugs.html
    "A spark plug shorted by excessive oil entering the combustion chamber is shown below. This is often caused by piston rings or cylinder walls that are badly worn. Oil may also be pulled into the chamber because of excessive clearance in the valve stem guides, or badly worn valve stem seals. If the PCV valve is plugged or inoperative, it can cause a buildup of crankcase pressure. This condition can force oil and oil vapors past the rings and valve guides into the combustion chamber."
    Being 12k miles; I'd highly doubt the rings and walls are worn unless some water/abrasive got into the fuel/oil system. The excessive clearance could have been caused by the extreme revving on a non-loaded(tranny not engaged) engine and the computer did not adjust the valve timing correctly allowing some oil to pull through. As previously mentioned, try replacing the spark plugs and test the coils for voltage. If the spark plugs are still being oil fouled, you may have a bigger task on your hands.
  11. Jun 9, 2010 at 12:58 PM
    aficianado
    back to bone stock.
    i vote bent valves. seen it 4 times in my life. motors dont like free spinning. cheap compression and leak down test. eliminate the obvious first, before breaking any gasket seals..
  12. Jun 9, 2010 at 1:25 PM
    makim
    whats the easiest way to check the compression?
  13. Jun 9, 2010 at 1:26 PM
    makim
    yeah but in this case, the spark plug is not covered by oil, just the threads
  14. Jun 9, 2010 at 1:31 PM
    aficianado
    back to bone stock.
    you need a compression tester. honestly take it somewhere. cant cost that much to have compression and leakdown tested. you need an air compressor anyways.
  15. Jun 9, 2010 at 2:09 PM
    #35
    Brandon###
    My vote is that everyone is over reacting. It was reved to 5500 for 3 seconds. Give me a break. You can tear into the engine if you want, but I bet nothing is wrong with it. How fragile do you think these engines are?
  16. Jun 9, 2010 at 2:58 PM
    #36
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    I do not think they are the valves, the engine is too new to fail so...
    I keep saying check the Ignition Coil`s,
  17. Jun 9, 2010 at 3:04 PM
    #37
    aficianado
    back to bone stock.
    what does mileage or age of motor have anything to do with this? what do you think will happen to a coil, on a over rev?
  18. Jun 9, 2010 at 3:19 PM
    #38
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    a Ignition Coil can fail any time, I already had that problem with a other car, and are the same symptoms.... mechanical things do not fail so fast, with so little mileage, if they have good oil and maintenance at day... the engine have 12000 miles...it`s basically new..
  19. Jun 9, 2010 at 3:30 PM
    #39
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    makim, take a Ignition Coil of a friend from you with a FJ Cruiser, and change the Coil one by one in your truck .. and you can se if some fail, and the engine run better..., if it in the 6 changes, the 6 coil no fail, then you discard the problem...
  20. Jun 9, 2010 at 5:47 PM
    #40
    aficianado
    back to bone stock.
    night..do you understand the mechanics on what happens on an over revd motor?
    has nothing to do with mileage or age of motor.
