fj cruiser owner needs help with 4.0L (pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by makim, Jun 9, 2010.
  1. Jun 9, 2010 at 6:13 PM
    #41
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    OK, once you do the obvious visual check to insure that no hoses or wires have fallen loose, the next step in diagnosing this kind of problem (reduced power) is a dry & then wet compression test; & if that shows a low cylinder do a cylinder leak-down test on the low cylinder. From that you can tell if it's rings or valves and which valve as well (usually.)
    If just one cylinder doesn't make and hold compression, then all the fiddling with gaskets, sparkplugs, and coils is just wasted effort.
    There's a possibility of oil starvation to the cams as well, & you might have scarred a cam lobe & lifter. If the compression & leakdown tests don't tell you anything, then pull the valve covers & look at the cam lobes.
  2. Jun 9, 2010 at 6:27 PM
    #42
    night_angel
    night_angel Well-Known Member
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    ECU FT500, JBA Headers, 100% Offroad
    I understand a loot of mechanics...
    revd motor , it`s for me, accelerate the engine to the cutting... 7000rpm? or 6500rpm..., where the ECU cuts the ignition and fuel... and the Ignition Coils not like that...it`s not the ideal...
    I not say the valves are not the problem, that can be .. but, I dont tink so.. I hope the owner answer what really happened after in this topic...
    exactly Caddmannq +1 for that opinion
  3. Jun 10, 2010 at 5:18 AM
    #43
    makim
    makim [OP] Well-Known Member
    ignition coil looks good, where would it get damaged, at which point?
  4. Jun 10, 2010 at 5:20 AM
    #44
    makim
    I cleaned the spark plugs, took it for a drive (20 miles), removed the spark plugs and they looked clean. So now I will check the compression , thanks for your input ;)
  5. Jun 10, 2010 at 5:23 AM
    #45
    makim
    I had toyotas and hondas all my life, well designed motors imo, but think about it, it's 4 liter engine, very close tolerances, huge loads (at high rpm) so things can get damaged in a fraction of a second
    This engine sounds different, vibrates, and top end power isnt the same when I downshift and accelerate. It could be nothing or it could be damaged piston ring....but I dont even wanna think about that now
  6. Jun 10, 2010 at 6:30 AM
    #46
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    One (in my mind) slim possibility is a damaged or partly clogged fuel injector. I say "slim" as I would normally suspect this right off, but not as a result of just revving up the engine. I really suspect that it's a case of oil starvation related mechanical damage.
  7. Jun 10, 2010 at 6:58 AM
    #47
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    makim...i hope and pray everything works out.
    hope those valves didnt meet those pistons. please keep us posted. just cant rap my mind about some wire falling off, or coming loose because the motor was rev'd up in a driveway somewhere. rev limiters cant save a motor from momentum..physics is a bitch.
    again, please keep us posted.
  8. Jun 10, 2010 at 7:01 AM
    #48
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    the damage of the coil you can not see it .. is internal..
    the outside may be new .. and inside to be burned/dameged..
  9. Jun 10, 2010 at 7:09 AM
    #49
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Any chance of bad gas in Poland?
  10. Jun 10, 2010 at 8:10 AM
    #50
    Brandon###
    Brandon### Well-Known Member
    You said you cleaned the plugs, drove it 20 miles, checked them and they're still clean. If you had a damaged ring you would know it. You would have smoke coming from the exhaust and it would run like crap, and most likely give you a check engine light.
  11. Jun 10, 2010 at 9:13 AM
    #51
    makim
    Caddmann as much as I want you to be wrong, it's either that or crapy european gas-clogged injector
    Caddman how can I check for bad injectors without any high tech tools?
    pretty much everything here is diluted, Vodka, gas, mouthwash, deodorants ;) I miss US
  12. Jun 10, 2010 at 9:17 AM
    #52
    Duck760
    Duck760 The Duck
    you will have to remove the valves as well and on the bottom side there well be 8 rubber rings I just replaced them on my honda witch has 240k miles on it. wow only 12k miles thets cbsered
  13. Jun 10, 2010 at 9:30 AM
    #53
    makim
    you have to remove valves to get to injectors?
  14. Jun 10, 2010 at 10:29 AM
    #54
    Brandon###
    Can someone explain how reving up an engine would clog an injector?
  15. Jun 10, 2010 at 10:49 AM
    #55
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    good point...
  16. Jun 10, 2010 at 11:07 AM
    #56
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I'm on my iPhone so I'm not going to read this whole thread. I would talk with xrunnit. He knows more about high rpms on these motors then most.
  17. Jun 10, 2010 at 11:08 AM
    #57
    Brandon###
    If it will help your friend who is being accused of damaging your engine by revving it to 5500 for 3 seconds, I will video my truck revving to 6000 for 8 seconds, and prove that it doesn't damage anything. There's no way it damaged a coil pack, valve seal, ring, injector, etc... these e-diagnosis are just getting silly now. engineers put these engines through a series of hellish tests before they are blessed and put into production. Reving one for 3 seconds will not hurt it
    If you actually have a problem with it, it wasn't causedby him. You should just take it to a shop and have it diagnosed properly.
  18. Jun 10, 2010 at 11:36 AM
    #58
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    I'd like to see the video for the hell of it..
    I just try and fill it up with 91 octane and some gas treatment and drive 50 miles and see how its running then.
  19. Jun 10, 2010 at 12:00 PM
    #59
    makim
    pm sent
    Im not acusing anyone, shit happens, gas in europe is and always was shitty, so it could be clogged injectors, who knows, I'm taking it to toyota regardless, someone has to take a look at it
  20. Jun 10, 2010 at 12:17 PM
    #60
    makim
    toyota uses chains which are 10x stronger, so I ruled out bent valves
    it's not like you're not gonna notice that kind of impact
    just to make it clear, the car runs ok, but it idles worse then before, feels like it lost about 20hp, no codes etc
    when I accelerate beyond 3500rpm it feels and sounds like a civic, less torque, I dont know how to explain it any better
    as far as maintenance: I changed oil, filter, checked and cleaned spark plugs, air filter, checked intake manifold......not sure what else I could do...
