FJ Cruiser T-Case Install in 2007 Tacoma 6-Speed Manual
Discussion in 'Garage / Workshop' started by SuthrnTaco07, Oct 13, 2011.
  1. Sep 4, 2012 at 8:31 PM
    #61
    BIGchar33597
    BIGchar33597 Well-Known Member
    char
    Sumter Co. Florida
    2008 Tundra 5.7 4x4
    Thought about that...
  2. Sep 4, 2012 at 8:42 PM
    #62
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    Subbed for when I get me a second gen
  3. Nov 12, 2013 at 12:25 PM
    #63
    aw113sgte
    aw113sgte Well-Known Member
    One thing I don't quite follow, I would like AWD on my Tacoma...Since the FJ AWD box is a little longer, all I would need to do is get different length drive shafts? I have a manual so as I read it, the splines would match. Obviously some electrical stuff would be needed, but mechanically, V6 6spd->AWD FJ transfer case->modified drive shafts would work right?
  4. Nov 13, 2013 at 8:44 AM
    #64
    smittyt2k6
    smittyt2k6 New Member
    Yes, with a modified driveshaft the AWD transfer case will swap in as long as you match the spline from the 6sp.
    Something to think about though... your tacomas front end was not designed to be spinning all the time, especially at highway speeds for a long duration. You will obviously see a lot more ware on the area and I'm sure your gas milage will plummet.
  5. Nov 14, 2013 at 4:25 AM
    #65
    aw113sgte
    Wouldn't the spline already match though? The AWD box matches to the FJ 6 spd from the factory....unless the Tacoma 6spd is different?
    The gas mileage issue has been proven incorrect. The FJ80 guys though the same thing so they made part time kits, when the from was disabled there was no measurable difference in economy.
    As far as durability, I believe the FJ auto and FJ 6spd have a basically identical front axle as the Tacoma, with no increased wear. Most everything is already spinning anyways (just without load) when in 2wd.
  6. Nov 26, 2013 at 7:16 AM
    #66
    tacoma4
    tacoma4 Well-Known Member
    So I'm thinking of doing this to my truck but I've got some questions:
    1. It seems like the transfer cases are all the same on Tacomas, so this will bolt up to my 5 speed manual, 4 cylinder just like the 6 speed? I will just have to swap the gear sets between the AT transfer case and mine?
    2. On the RST page, he says if you aren't using a crawl box, you need to twin stick it to have room for the sticks in the cab. But it looks like you didn't do that. Is there room for the J-shift single stick to move around in the cab? Is this because you are manual trans and not the auto?
    3. I have the bench seat, has anyone done this as a single stick and seen if the seat causes any issue?
    Thanks for the writeup, hope to try this over xmas is if works out!
  7. Jan 20, 2015 at 12:48 PM
    #67
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
  8. Feb 24, 2015 at 8:13 AM
    #68
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    Can you swap the input flange on the automatic transmission and manual transmission instead of the transfer case side?
  9. Feb 24, 2015 at 8:19 AM
    #69
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    What are you talking about? The diff and axels are always spinning. Do you have an actual mechanic design to cite or are you just making his assumption based I the fact that the Tacoma did not come AWD from the factory?
  10. Feb 24, 2015 at 9:04 AM
    #70
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    i dk but i intend to find out....... :popcorn: :anonymous:
  11. Aug 5, 2016 at 10:28 PM
    #71
    MuddyTacoma9
    MuddyTacoma9 Member
    06 tacoma
    I know this is an old forum but im dying to do this to my 2006 Tacoma 6 speed! Any ways what year fj case is it or is it simply just an automatic fj transfer case. Thanks
  12. Aug 6, 2016 at 12:24 AM
    #72
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Holy thread necro. but, to answer your question, any model year FJ will work, as they never made any drivetrain changes through the years. however it must be an FJ Cruiser, earlier model FJ cases wont work. 2006-2014 to be specific.
  13. Aug 6, 2016 at 12:46 AM
    #73
    Gaunt596
    Matthew
    Central Maryland
    And on a side note, looking at this im damn curious if similar things can be done to the Tacoma/FJ cruiser.
    Biggest thing i can see off the bat would be having our driveshaft shortened to accommodate the longer case, and making the spacer to lock the front diff into 4wd/AWD mode. or do the mod to control the front diff and have the options of 2WD,AWD, AWD 50:50, AWD Low, and 2WD low, all with two switches
  14. Aug 6, 2016 at 9:41 AM
    #74
    MuddyTacoma9
    MuddyTacoma9 Member
    06 tacoma
    Thank yall for the help!!! 2 low and a 4x4 lever instead of a stupid knob! Thats the best upgrade ever!!!
  15. Sep 16, 2016 at 1:06 PM
    #75
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    One thing I couldn't find an answer to is how this plays out with the elocker axle. RST instructions for making the dash lights for 4hi and 4lo work are pretty fool proof but what about the axle lock indicator light?
    I believe that's also governed by the 4wd ECU... Would not want to lose that for safety... and aesthetics....
  16. Sep 16, 2016 at 7:38 PM
    #76
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    You just do the locker anytime mod and your set
  17. Sep 16, 2016 at 8:44 PM
    #77
    TireFire
    Olympic Peninsula
    You mean grounding the 4lo and 5mph safety wires? That's how you get the locker to come on any time but I don't know how this answers my question regarding the locker dash lights when you remove the 4wd ECU
  18. Sep 16, 2016 at 10:11 PM
    #78
    Basikbiker
    Trav
    my lights work like theyre supposed to
    TireFire likes this.
  19. Sep 16, 2016 at 10:12 PM
    #79
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Ya, just did this swap with twin sticks and now I'm going to do the locker anytime mod
    TireFire[QUOTED] likes this.
  20. Sep 19, 2016 at 9:50 AM
    #80
    TireFire
    Olympic Peninsula
    Looks like you have a 4x4 offroad also... Could you let me know how you retained the dash lights for the locker?
