FJ Cruiser wheels on Tacoma Off-Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grossolj, Jul 23, 2020.
  1. Jul 23, 2020 at 9:43 AM
    Grossolj
    Grossolj [OP] Member
    Lenny
    2018 TRD Off Road
    Hello everyone!
    I have the chance to buy some FJ cruiser 17 inch wheels for a really good price. I have a 2018 Off-Road and everything I can read says they should fit. Is there any reason not to make the jump to bigger wheels?
    Thanks for your help!
    Lenny
  2. Jul 23, 2020 at 10:29 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I’d do it. The only downside is your speedo and Odometer will be off a little. I run 16” Wheels from an ‘08 FJ on my T100. At highway speeds the speedo reads slow by 7ish MPH’s.
    Grossolj[OP] likes this.
  3. Jul 23, 2020 at 10:32 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I'm running FJ Steelies 17" on mine with no problem.
  4. Jul 23, 2020 at 10:39 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Going up to 17 inch wheels to a +1 tire actually improved my mph. I was told by a dyno operator that checks and calibrates speedometers for a living that typical factory calibrations are +/- 5% of error.
  5. Jul 23, 2020 at 4:05 PM
    Grossolj
    Lenny
    2018 TRD Off Road
    Is there anyway to change the settings for a 17 inch wheel?
  6. Jul 23, 2020 at 4:22 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
  7. Jul 23, 2020 at 4:23 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You may not need to change anything.
    When I put 2012 FJ Cruiser Trail Edition wheels onto my 2003 TRD OffRoad and bumped up to 32" tires, my speedometer is now about correct. Before with 31" tires, the speedometer was showing higher than actual speed ~62 when going 60mph.
  8. Jul 23, 2020 at 4:24 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Did the FJ wheels come with tires? Seems like it may not be a good deal unless it did.
  9. Jul 23, 2020 at 4:30 PM
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    If you are running 265x70x16s on your OR and mount 265x65x17 on the FJ wheels there should be no adjustment needed. Those wheel/tire combos are the same diameter.
  10. Jul 23, 2020 at 4:41 PM
    smikec
    smikec Well-Known Member
    as already said, the wheels do nothing to the speedometer
    its the tire circumference that matters
    do they come with tires? if yes, what size?
  11. Jul 23, 2020 at 7:16 PM
    Grossolj
    Lenny
    2018 TRD Off Road
    Thanks for all of the information. Its very helpful. Two of the wheels have tires. I will check on the size.
    Thanks again.
  12. Jul 24, 2020 at 3:21 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    To answer your initial question, tire selection is better for 17 inch wheels than for 16s.
    Once you decide on tire size you can use the tire size calculator to determine how far off you might be in your speedometer keeping in mind the factory calibration can be +/- 5% compared to GPS.
    https://www.tacomaworld.com/tirecalc
