fj owner needs your help part 2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by makim, Jul 5, 2010.
  1. Jul 5, 2010 at 9:27 AM
    makim
    makim [OP] Well-Known Member
    well I finally took my fj to a mechanic, the first thing he did was remove the valve covers, here's how it looked
    injectors are fine, spark plugs/coil were checked and are ok
    top end power is definatelly the same, but at low rpm 1000-2500 car sounds louder and definatelly lost power
    if anyone out here has any idea what else it could be , please share
  2. Jul 5, 2010 at 9:57 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Do the basics first.. compression test and a leak down test. Are you smoking at all? Just taking off a valve cover isnt going to show you anything really. Do those two tests and see what numbers you come up with. If that all pans out perfectly, check on your tranny. Louder and lost power could be found there..
  3. Jul 5, 2010 at 11:30 AM
    makim
    compression is ok, taking off valve covers would show oil starvation damage, that many here suggested...
    is it possible for the timing to change by itself?
  4. Jul 5, 2010 at 11:32 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    if the chain gets stretched or it jumps a tooth/chips a tooth.. or if you have a belt and its old.. but usually no. Timing wouldnt cause this sort of issue anyway
  5. Jul 6, 2010 at 7:26 AM
    Brandon###
    Brandon### Well-Known Member
    Pay $75 and have it dyno'd. That will give you a clear pic on the power loss. Its cheaper than paying someone to take it apart and find nothing wrong with it.
    Does the mechanic agree that something is wrong with it?
  6. Jul 6, 2010 at 7:34 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Why did he take the valve covers off? You can't tell much by looking in there. Do the easy stuff first - a compression test will give you an indication of a lot of things.... rings, valves, valve guides, etc. After that, get it on a Toyota analyzer. A dyno won't tell you squat unless you have a baseline to compare it to. Make sure the ECM is controlling the timing as it should - that could radically impact torque at any rpm, depending on what it's doing. Don't spend a bundle of $$ on mechanics that don't have the experience with Toyotas or the computerized equipment to properly diagnose. This isn't like the old days where you can look at the color of a spark plug and figure out what the engine is doing....
  7. Jul 6, 2010 at 7:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How old is this vehicle? What year? How many miles? Is it still under warrantee?
    How much maintenance have you done lately?
    How long have you had this condition?
    Have you done?
    Checked/changed air filter
    Checked/changed spark plugs/wires/connections
    Checked fuel pump
    Checked or cleaned fuel injectors
    Checked or cleaned your MAF sensor
    I'm sure there other things you can check that I'm not mentioning.
    Sorry - had to mention this stuff since you never really gave us any information otherwise.
  8. Jul 6, 2010 at 9:08 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Dyno would be interesting.. but compression test and leak down tests will tell you how strong that engine is. Taking off the valve cover and snapping pictures doesnt do much.. gotta say. You say compression is okay.. but still do a leak down. Check those two tests first and you'll get a good idea about how strong that engine is.
  9. Jul 6, 2010 at 10:04 AM
    Brandon###
    The info was in his previous thread. His friend rev'd up the fj to 5500 for approximately 3 seconds, annd he thinks something is damaged now.
  10. Jul 6, 2010 at 10:13 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Why he does not continue in the same thread :confused: :rolleyes:
    I still think its a vacuum line problem and nothing mechanically but I am too lazy to look for his old thread. :D
  11. Jul 6, 2010 at 10:19 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    that wont do anything to any engine properly put together.
  12. Jul 6, 2010 at 10:23 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    If it was JUST Rev'd it should be fine, that is what the limiter is for. If it was a manual and down shifted into a lower gear where it could possibly go above the red line mark the rev limiter would be useless and you could have bent some valves. A Compression/Leak down check would find this.
    You should also have your catalytic converter checked, along with the rest of the exhaust system for clogs or leaks. Does your FJ Smell like rotten eggs?
  13. Jul 6, 2010 at 10:55 AM
    makim
    I pretty much did everything, checked injectors, maf, all connections, spark plugs (4 times), air filter, intake is spotless
    no smell whatsover, just loss of power (low end), and different exhaust sound, sounds partially like a chopper.....
    It only sounds like that under load when accelerating
    top end power is the same, it pulls to 110mph like before, but from 0-60 it sounds different and feels like it lost a cylinder or two
  14. Jul 6, 2010 at 10:57 AM
    makim
    I think, and I know something isnt right
    I dont care what it is, my lawnmover, my wifes hair dryer, when something is not working right, I hear it and feel it
    guys come on give me some credit, I got a college degree and years of experience working on all my cars
    this biatch with all the sensors, vvti.... is just out of my league
  15. Jul 6, 2010 at 11:04 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    haha we're not saying anything bad man :) just trying to figure it out.
    Try the leak down test. if youre losing power, then theres a significant problem and i cannot see how it would be computer or whatever. throw some of that fuel injector cleaner in your tank too.. just for shits and giggles.
  16. Jul 6, 2010 at 11:09 AM
    makim
    Imagine my position, a brand new car, no warranty and people say you're crazy :D
    shit this car had amazing low end grunt, now its a freagin CIVIC DX
    I tried the injector cleaner and tested the injectors, all fine, took the valve cover off because, oil starvation damage was the last thing I suspected
    now it feels like a bend valve, exhaust side, which would cause a different exhaust note, but then top end power is fine, so again maybe cam position/vvti sensor.......
  17. Jul 6, 2010 at 11:11 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    out of warranty i'm guessing>?
  18. Jul 6, 2010 at 11:17 AM
    makim
    yeah, I live and work in europe, us warranty doesnt transfer here
  19. Jul 6, 2010 at 11:18 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    any chance you have some exhaust problems cracked pipes or whatever that might explain the loss of low end and would definitely explain the noise.
  20. Jul 6, 2010 at 11:22 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2, maybe a hole in the muffler or headers thats causing the noise and loss of backpressure
