FJ rear FOX Shocks from ORW
Discussion in 'Suspension' started by CaptMorgan, Dec 17, 2010.
  1. Dec 17, 2010 at 11:43 AM
    CaptMorgan
    CaptMorgan [OP] Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
    Don't know if this is common knowledge or posted be fore but... I ordered up the FJ cruiser rear Fox Shocks from OffRoad Warehouse today. Went this route since they are considered OE replacements and the Tacoma version really only accommodate a 1” lift at 22" long ext. The best I could find on the Icon rear resi's was that they are 24.1" ext and ORW has the FJ Fox's that are 24.4" ext.
    I had already planned to do this, but the rep suggested it before I got to mention my plan and he even knew I would need different bushings and sleeves for the bottom, what an awesome experience. I was planning to get the Icons, but going this route saved me some $ and I like the piggy back resi's instead of the frame mount of the Icons:headbang:
  2. Dec 17, 2010 at 11:45 AM
    CaptMorgan
    Tempe
  3. Apr 2, 2011 at 7:30 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Bump can you please post up the info you got regarding this? Did you have to make the bumps higher "longer" to accomodate this as I am in the same boat right now and need a definite answer very soon. I am going to be running J66 leafs with whichever Fox shock is best suited.
  4. Apr 2, 2011 at 7:36 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    OME suspension ARB OBA ARB locker
  5. Apr 2, 2011 at 7:41 PM
    08pretaco
    az
    Hey Paul, I added some possibly useful info to the other thread as well :)
  6. Apr 2, 2011 at 7:52 PM
    CaptMorgan
    Tempe
    Sorry, not sure what you guys are looking for. Install went great and they ride amazing.
  7. Apr 2, 2011 at 7:54 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    Ok Thanks.
  8. Apr 2, 2011 at 7:55 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    Ride quality, do the shocks top out during full compression, or still hit the bump stops? Im searching to see if the front can be set up for the extra travel aswell.
  9. Apr 2, 2011 at 8:07 PM
    08pretaco
    az
    Ya the front can. You need uniball uca's and get the extended travel coilovers. Thats what I just ordered
  10. Apr 2, 2011 at 8:44 PM
    CaptMorgan
    Tempe
    I am still bottoming out on the bump stumps when I take a big hit. I've thought about getting timbren bumpstops to smooth out the bumps.
    Hope this helps
  11. Apr 2, 2011 at 8:49 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    How bouncy are those timbrens? I was looking at the super bumps from wheelers but still on the fence! Sorry, not trying to thread jack!
  12. Apr 3, 2011 at 12:23 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    Yes it dose, Thank you
  13. Apr 3, 2011 at 12:31 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
  14. Apr 3, 2011 at 1:05 PM
    08pretaco
    az
    ya FJ shocks put the resi on the top, tacoma shocks put the resi on the bottom behind the wheel were no one can see it lol
    you need to be running a lift to run the FJ shocks as the lengths are not the same as a factory ride height tacoma
  15. Apr 3, 2011 at 1:07 PM
    TmecTaco79
    Adam
    Escondido,CA
    Cool thanks. Ya I'm planning on getting a 3" lift in the rear so these should compliment it nicely:D
  16. Apr 3, 2011 at 1:10 PM
    08pretaco
    az
    Actually, from my other thread: http://www.tacomaworld.com/forum/suspension/149449-fox-rear-shocks-fj-tacoma.html,
    To be able to really use the rear to the fullest extent you might want to reconsider which shocks to use. Bilstein uses a 16" collapsed and 27" extended shock for a 3-4" lift. I dont think the Fox will be long enough for you....its your truck man I am just throwing out some food for thought
  17. Apr 3, 2011 at 1:21 PM
    TmecTaco79
    Adam
    Escondido,CA
    Oh ok. Thanks for the heads. I definitely don't want any problems later on down the road.
