FJ Steelies
Discussion in 'Wheels & Tires' started by Boulder Taco, Jan 2, 2012.
  1. Jan 2, 2012 at 2:54 PM
    Boulder Taco
    Boulder Taco [OP] Well-Known Member
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    3" ToyTec Lift BFG MT KM2 255/85/16's ProComp ES9000 Shocks Avid Light Bar / Sliders Hella Black Magic Fog Lights Black Badges + Black Grille ARE Topper Sockmonkey TRD Decal Bulletproof Fab. TRD Skid Plate
    I'm interested in putting the stock black FJ Steelies on a new 2012 Tacoma TRD Offroad with a 3" lift. I want to keep a 16" rim. Do 16" Black Steelies exist? I have only seen 17"!?!
    Also, what is the biggest tire I can safely put on a 16" rim with the Toyotech 3" lift?
  2. Jan 2, 2012 at 4:04 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The 17 FJ steelies not only are not the right size for the 16 tires, but they also don't have the ideal backspacing to run 285s with your 3" lift. You could only run 265s.
    http://www.wheelersoffroad.com/tacomawheels.htm
    If you run these wheelers type a steelies above in 16, you can run the 285/75/16s with some trimming.
  3. Jan 3, 2012 at 6:07 PM
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    Thanks! I appreciate the help. Can I run that 16" steel rim with a 275/75/16 tire? I think the width is just shy of 11"
  4. Jan 3, 2012 at 6:10 PM
    KPT
    09 Prerunner
    Yep you should be fine wit that size because of your lift.
