FJ TRD Brake Kit on Tacoma?
Discussion in 'Technical Chat' started by KenLyns, Oct 27, 2011.
  1. Oct 27, 2011 at 7:29 PM
    KenLyns
    KenLyns [OP] 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
  2. Oct 27, 2011 at 7:31 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    They're typically installed on X-Runners. It doesn't work (easily) with LT kits (not sure if that matters to you or not).
    Should work fine though, since the suspension is pretty much the same (front end wise) on the FJ and the Tacoma, so it should bolt right up
    Edit: According to TRD Catalog they work with a 16" Rim?
  3. Oct 27, 2011 at 7:50 PM
    KenLyns
    Belly of the Beast
    The X-Runner kit is 5-lug. There is no official kit for 6-lug Tacos. That's why I was asking if the FJ kit would work on a 6-lug Taco.
    Thanks. Looks like it has been done before? :)
  4. Oct 27, 2011 at 7:57 PM
    theduck911
    Max
    Locked and Geared!
    If it does fit, I'd be interested in doing it, Looking at the TRD Catalog it shows a FJ with a 16" Rim & the Big Brake kit, so it should work fine on a Tacoma?!
  5. Oct 27, 2011 at 8:26 PM
    KenLyns
    Belly of the Beast
    Since the stock brakes are powerful enough to lock up the wheels, theoretically no upgrades are necessary for "casual" use - you'll get the same stopping distance because your tires are the limiting factor. The benefit of the Stoptech kit would be better initial "bite", and better heat dissipation, so repeated panic stops from 60 mph wouldn't cause fade as quickly.
  6. Nov 28, 2011 at 11:46 AM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    So the factory offroad TRD brakes are just as good as these?
  7. Nov 28, 2011 at 11:59 AM
    amain
    amain Well-Known Member
    Brian
    Seattle, Washington
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
    I have installed the TRD kit on my FJ and I have to say it is not worth the money but they look nice. For about 1/3 of the price you can get a kit from Supreme Power that will give you about the same slotted and dimpled rotors. Another big improvement is changing your lines to SS. You can also upgrade the fluid to DOT 5.1 for the highest boiling point.
