FJ80, a good buy in today's market?
Discussion in 'Toyota Trucks & SUVs' started by Ozark_RegCab, Aug 20, 2021.
  1. Aug 29, 2021 at 10:30 AM
    #101
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Yeah if the comp test is bad I'll just assume it needs a top end rebuild.. let's hope it doesn't come to that. Maybe I should get that done before anything else..
  2. Aug 29, 2021 at 10:36 AM
    #102
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Do a block flush, there's a block plug on the drivers side. I got more junk out there too than with a regular flush.
    Ozark_RegCab[OP] likes this.
  3. Aug 29, 2021 at 10:43 AM
    #103
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I was gonna follow these steps: https://forum.ih8mud.com/threads/coolant-flush-process-verification.107438/ (Not the main post, but the first comment by Cary).
    You think starting with a garden hose til it runs clean, then flushing through a few gallons of distilled water would be a good idea?
    Or would it be more efficient to take it to a shop where they can use a machine? Either way a flush is definitely needed as the coolant looks kinda rust colored. I hope they didn't use Dexcool..
  4. Aug 29, 2021 at 10:52 AM
    #104
    stevesnj
    Once the radiator is sorted it's not hard to do a flush. Yeh you can run hose water with a block flush. That will get all the hose water out then you don't need to re flush with distilled, as long as all the hose water is out of the other parts of the cooling system.. That plug leads right to the cylinder sleeve water jackets and is angled to the the flush plug so all the water will come out of the block. I removed the thermostat, reassembled the housing without the thermostat in, opened my heater valve to flush that, and pulled the block plug. I used the top rad hose and stuck my garden hose in there for like 10 min. To me that flushed it fully. And yes do a rear heater bypass. Easy to do. Buy the best constant tension hose clamps you can get. You don't want to keep tightening those, especially the PHH clamp.
  5. Aug 29, 2021 at 1:38 PM
    #105
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Do a few fluid changes then just drive the damn thing! Don't get too caught up getting it squared away before you can enjoy it.
    This morning I went and tried to buy another, the guy wasn't home. :anonymous:
    208k. kind of beat up, but very rust free. If I can get it cheap enough I might steal a few parts to clean mine up then flip it...
  6. Aug 29, 2021 at 8:30 PM
    #106
    Ozark_RegCab
    Nick
    Northwest Arkansas
  7. Aug 29, 2021 at 8:33 PM
    #107
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Plan to tackle that this week. I think I'll stick to a flush and PHH/Tstat replacement. I've heard the heater hose thing is a PITA though, so I've got something to look forward to.
  8. Aug 31, 2021 at 7:17 AM
    #108
    stevesnj
    I’d do the rear heater bypass since those heater hoses need to be replaced.
    Ozark_RegCab[OP] and Speedytech7 like this.
  9. Aug 31, 2021 at 7:20 AM
    #109
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Have a new heater control valve on hand or at least a piece of 5/8" pipe on hand cause with that valves age and appearance you're about 50/50 on breaking the nipple right off.
  10. Aug 31, 2021 at 9:49 AM
    #110
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Thanks. These were the steps I was gonna follow for the cooling system "baselining." I was also thinking about refilling the fan clutch and checking its timing.
  11. Sep 8, 2021 at 10:26 PM
    #111
    MonsieurHodge
    MonsieurHodge Well-Known Member
    Nick
    Carmel Valley, CA
    2014 Blue Ribbon TRD Off Road AC 4x4 V6 6MT
    I just picked this up last week! 95 FZJ Triple locked.
  12. Sep 9, 2021 at 7:09 AM
    #112
    Ozark_RegCab
    Nick
    Northwest Arkansas
    That's a gorgeous rig, congrats! I'm guessing it cost you a little more than my humble stock 80. Looks like a turn-key truck though; how many miles?
    skidooman likes this.
  13. Sep 9, 2021 at 2:46 PM
    #113
    MonsieurHodge
    Nick
    Carmel Valley, CA
    Yeah it was quite a bit more... the market is crazy right now. But it's really worth it for all the work done on it. it's at 200K, literally just turned over. Barely broken in ;). Yours is quite nice too I love the green.
  14. Sep 9, 2021 at 2:52 PM
    #114
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It's actually black, but it can look dark blue or green depending on the lighting lol. At least the clear coat isn't faded. Mine has 226k. Do you know if yours has a new top end?
  15. Sep 9, 2021 at 9:19 PM
    #115
    MonsieurHodge
    Nick
    Carmel Valley, CA
    Yep, I helped the PO do the rebuild. It’s pretty much ready to go! I need to figure out a beefier cooling solution though. Bigger fan/fan clutch from a 100 series is what I hear people do. Any tips are much appreciated.
  16. Sep 9, 2021 at 9:49 PM
    #116
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I've heard blue fan clutch is the way to go.
    I've also heard TYC 1918 radiators are the best.
    MonsieurHodge[QUOTED] likes this.
  17. Sep 10, 2021 at 7:22 AM
    #117
    stevesnj
    There's a "fan clutch mod". You get a blue shaft fan clutch and replace the oil inside with a thicker grade oil and it works amazing actually. The mod is on the Mud forums. Very easy to do. You can probably do it on the standard clutch too. Just buy a new clutch and change the oil to 20k weight silicon oil
    Get the best aluminum radiator you can afford. Mine is a TYC but lots of fakes out there so search on Mud for a reputable vendor. Toyota red or Pentosin red (same formula) is made for the metallurgy of the 1FZ engine. Don't use anything else. Flush the block and system very well though. And new OEM thermostat.
    MonsieurHodge likes this.
  18. Sep 10, 2021 at 8:23 AM
    #118
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I'm kinda confused by the Toyota Red vs Prestone Green debate. Opinions seems to be split on Mud and on here too over whether Red is really better. I was leaning towards green because of the greater availability and due to my budget. I'm not saying you're wrong, but have you seen one overheat specifically because it had green instead of red?
  19. Sep 10, 2021 at 8:26 AM
    #119
    stevesnj
    It's not an overheat issue but formulation issue. The red is specific formulation for the 1FZ. I asked the machinist who machined my head an he said use the red and replace it every other year. He's been doing head machining for 30 years and said to use what the Mfg. put in. In this case Toyota red.
  20. Sep 10, 2021 at 8:31 AM
    #120
    Ozark_RegCab
    Nick
    Northwest Arkansas
    So you're saying the red formula can help prevent the alloy head from warping, all other things being equal? I wonder what about its chemistry would cause that.
    Do you think I'd have issues using green? I was also considering Zerex asian red, but I wanna do a real good flush in any case. The OEM stuff is hard to justify for my budget, but if it really is a case of buy once cry once I'll have to consider it.
