FJ80 Axles
Discussion in 'Solid Axle Suspension' started by thecarter999, Jan 29, 2015.
  1. Jan 29, 2015 at 10:56 PM
    thecarter999
    thecarter999 [OP] Member
    Josh
    Georgia
    2006 Tacoma
    I have a 2006 Tacoma I'm looking to SAS, Already have purchased all my 2in DOM link material and other key components to complete the swap. Looking to 3link the front and run leafs in the rear.
    I scored a dirt cheap amazing deal on a set of FJ80 Axles 4.10s with E-L ockers F/R.
    My question is:
    Would you run the FJ80s or go with a set of 60s?
    Besides the steering issue with the FJ80 what else might i run into?
  2. Jan 30, 2015 at 9:23 AM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    On a second gen seems like the general consensus is that anything but a dana 60 or the equivalent will not be strong enough. I don't know much about it but I do plan on using 80 axles on my 1st gen. Not sure what steering issues you are concerned about?
  3. Jan 30, 2015 at 4:44 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Fj80 axle will explode under a 2nd gen. If you were to do any sort of toyota axle on the 2nd gen it'd need to be a 9.5" center with a custom housing with either Fj80 outers (hellfire knuckles)... But that'd be pricey as shit and gl getting hellfire knuckles... I've heard they are slow lead times.
    I'd reccomend just doing a dana 60 ford or get a 9.5" center with custom housing and slap dana 60 outers on it. BALLIN'
  4. Jan 30, 2015 at 4:49 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Get D60s and sell me the front 80 for the dirt cheap price you got it for. I'll even drive to Georgia and pick it up :D
  5. Jan 30, 2015 at 8:43 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I disagree on the 80 axle not being enough for a second gen.. an 80 weighs 4750 stock and a second gen double cab tacoma weighs 4100, lots of people wheeling 80's without exploding axles.... With links you don't have to worry about hi steer like you do with leafs on an 80 axle either. The HP 8"is pretty darn stout with strong as hell stock birfs to boot..
  6. Jan 31, 2015 at 7:16 AM
    Supra TT
    Eric
    Indiana
    The 8" is WEAK. it's a freaking 8", people are blowing them up in the tacos all the time... Granted, it's not the HP version but it's still weak. People ruin 9.75" RGs which are a majority of the D60s.
    Just because a "stock dbl cab" is 4100 does not mean that's what it's going to be when the SAC is done. Try more like 5k+ EASY, with tires that are 7-12" BIGGER than a Fj80 STOCK.
    By all means, run the 8" HP and stock birfs... Good luck.
    Maybe if the OP is going to run 33s or 35s I'd say sure go for it. Might get away with 37s if you're a pussy.
  7. Jan 31, 2015 at 9:37 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    So what about the built 80's that get wheeled hard on 37's and 40's? That's an easy 5500 lb truck. Would a 9.5 center be better, yeah, but it doesn't mean that an 80 axle is a bad choice either..especially if he got a good deal on it.
  8. Feb 1, 2015 at 1:58 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I gotta agree. People wheeling built 80s on 40s, heavy 6500 lb rigs with these axles.
    With chromos your weak point will be the 8" center but doesn't mean you couldn't do it.
    However for the cost I think you might as well go 60 up front.
    Custom 80/9.5 front isn't out of reach either though.
  9. Feb 1, 2015 at 3:40 PM
    Supra TT
    Eric
    Indiana
    Dude D30s are free too. It's a good deal, may as well wheel it. Many jeeps still run the axle and do well with them! You can run whatever axle you want, doesn't mean you SHOULD.
    Take it from someone with the experience, and throughout several years of seeing the same shit over and over "I'm dumb, I should of gone tons in the first place"
    I made that mistake, it's costed me well over 10 grand already. And now, in order to swap to tons it's 5k minimum...
  10. Feb 3, 2015 at 11:48 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Got a buddy with 40's on his 80 with longs, wheels like crazy and its fine. He wheeled like crazy on 37s with the stock birfs and no breakage axle wise. Swap the 80 axles in and if you are a good driver you will be fine. If you prefer to stand on the gas rather than finesse it get some tons.
  11. Mar 22, 2015 at 1:29 PM
    krackem
    krackem New Member
    Zak
    Chattanooga,Tn
    A Piece
    Got a kingpin 60 & 14 bolt I'll trade you for those fj80 axles
  12. Mar 22, 2015 at 8:01 PM
    thecarter999
    Josh
    Georgia
    2006 Tacoma
    Krackem:
    What are the specs on your Kingpin 60 and 14 bolt
  13. Mar 23, 2015 at 7:06 AM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    I wouldn't hesitate to run FJ80 axles in a second gen. They'll weigh less than 1 tons and be just as strong with some upgrades.
    singletrack_ftw likes this.
  14. Mar 23, 2015 at 10:29 AM
    slander
    Hickory, NC
    We were discussing this over some beers in the garage this weekend, and estimate the fj80 chromo longs being in the same strength league as 35spline 60's. So if i was in your shoes i would: get a housing from ruff stuff to accept a 9.5" center, chop your knuckle balls and outers off the 80 axle and weld those onto the housing, get the steering figured out and wheel. You don't need to be like everyone else and run 60's. A 60 rear is a waste of time and not even that strong when compared to an 80rear or the 14bolt.
  15. Mar 24, 2015 at 7:00 AM
    thegame
    Brian
    Folsom, CA
    Yea a 60 rear is basically an FJ80 rear with Tacoma axle shafts. Almost all full float 60's are 30 spline. The only benefit is much lower gear ratios available.
  16. Mar 24, 2015 at 8:26 AM
    slander
    Hickory, NC
    I was referencing the dana 60 in my post. Dana 60 rears are a waste of time unless they come free with the front axle.
