Flag Mounting?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Oct 16, 2015.
  1. Oct 16, 2015 at 8:06 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I have a flag mount I drilled into the inside of my tailgate. I've seen people do it to their toolbox, how would I go about drilling it into my toolbox?
  2. Oct 16, 2015 at 8:56 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I would think it would be cleaner to weld on a tube to the side of the box. As to avoid allowing water to enter in.
  3. Oct 16, 2015 at 10:05 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I'm a little concerned with your request. I would think it's a simple drill some holes here and mount. You shouldn't need advice for this really.
    Am I wrong? Are there some other special circumstances you have? Get us some pics of where you wan't to put the mount and point out any obstacles.
  4. Oct 16, 2015 at 10:41 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I agree with undyingvisage58, if youve done it to your tailgate whats different about your bed box??
  5. Oct 17, 2015 at 2:37 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    The spacing. The top of my box sticks out further then the bottom
  6. Oct 17, 2015 at 2:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Shims under the mounting points. Or a single shim plate.
    Or be uber cool and french it into the lid (complete with drain) and up-light with an LED spot flush in the lid.
  7. Oct 17, 2015 at 5:29 PM
    CodeSeven
    Serge.
    Coachella Valley
    pretty much what he said. hmmm. what is there that you can use. some kind of stock material that sticks out further than the cover. wood is an easy solution though not very reliable over time. some autoparts stores sell hollow square welding bars that might be perfect. like this from lowes. you know, stuff like that. and you can always get like a bicycle tube, cut it into strips and use that as a sort of gasketing material so water doesn't get into the holes.
  8. Oct 18, 2015 at 9:12 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    just go buy 4 copper couplings size 3/8" and use them as spacers, it will give you a "stand off" of roughly 1/2" and wont rust or dry out over time.
    you can also simply use two spacers on top and none on bottom or bend the flag mount leaning backwards at about a 30 degree angle so it clears the lid. this is a much better look and keeps the flag "open" most of the time and is les likely to get wrapped up around the pole.
