Flag Pole Mount for the back of the bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GunMetalSteak, Jun 18, 2010.
  1. Jun 18, 2010 at 7:52 AM
    GunMetalSteak
    GunMetalSteak [OP] Active Member
    LA, CA
    07' PreRunner SR5
    Hood scoop, side steps.
    Hi, I have searched the forum and didn't find what I was looking for.
    I would like to install a temporary flag mount for the fourth of July.
    I found this thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/11029-flag-pole-bed.html
    and I might be able to do something like this. I am looking for something that I can strap in and easily remove. Any ideas? I do have the D rings in the front if that helps.
    thanks in advance.
  2. Jun 18, 2010 at 7:54 AM
    GunMetalSteak
    LA, CA
    07' PreRunner SR5
    Yeah I saw that too. Its nice, but I do not have a welding machine and it looks kind of difficult to do.
  3. Jun 18, 2010 at 7:55 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Subscribed...
  4. Jun 18, 2010 at 7:58 AM
    GunMetalSteak
    LA, CA
    07' PreRunner SR5
    the same size you use...what is that a 3'x5' ? the standard house flag...
  5. Jun 18, 2010 at 8:03 AM
    GunMetalSteak
    LA, CA
    07' PreRunner SR5
    yeah just one
  6. Jun 18, 2010 at 8:16 AM
    GunMetalSteak
    LA, CA
    07' PreRunner SR5
    great I will try it this weekend thank you.
    how fast do you think I would be able to drive if I secured it tight and also provided some lateral tie down supports?
  7. Jun 19, 2010 at 6:30 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    i will tell you that those adjustable flag pole mounts do not hold up well to speeds greater than 35+
    the teeth break pretty easily
    i ended up tossing that setup in favor of a sport mast
    http://wholesalesportmast.com/
  8. Jul 6, 2010 at 10:25 AM
    GunMetalSteak
    LA, CA
    07' PreRunner SR5
    So I found a down rod at lowes for $1.50 on clearance, cut it to the approriate length (i wanted metal so it would not break or bend.) Then I found a 6''x8'' block of wood and drilled the correct size for the down rod. I then wrapped the end of the down rod with duct tape and hammered it into the block.
    I strapped it down and I was easily able to go 80MPH+ no problems.
