Flange yoke??? need help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by htx6002, Dec 13, 2010.
  1. Dec 13, 2010 at 12:05 PM
    htx6002
    htx6002 [OP] Member
    houston texas
    taco prerunner
    ok so i need to fix my truck
    im not sure what the part is called..?
    flange yoke?
    yoke?
    idk but its where the drive shaft connects to the rear end
    does anybody know where i can find this part
    toyota told me i had to buy the whole drive shaft assembly that cost 900$
  2. Dec 13, 2010 at 12:17 PM
    htx6002
    htx6002 [OP] Member
    houston texas
    taco prerunner
    i added a pic that i found on hear
    can anyone please help me find this part online anything helps
  3. Dec 13, 2010 at 12:20 PM
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
  4. Dec 13, 2010 at 12:20 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    The left is the driveshaft, then U-Joint, Then the Yoke.
    First off, whats wrong, usually its just a U-Joint problem
    wilcam47 likes this.
  5. Dec 13, 2010 at 12:21 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    I have a spare one..... maybe... depends on which part you need.....
    Do you need the flange that is on the differential or the one that is on the actual driveshaft?
  6. Dec 13, 2010 at 12:42 PM
    htx6002
    htx6002 [OP] Member
    houston texas
    taco prerunner
    well it was just a u joint problem but didnt take care of it for A long time
    my drive shaft disconnected on the way to go fix it
    yeah the one on the differential broke
    thats the only part i need
    u have that part???
  7. Dec 13, 2010 at 12:45 PM
    htx6002
    htx6002 [OP] Member
    houston texas
    taco prerunner
    i have an 06 tacoma double cab sb 2wd by the way
  8. Dec 13, 2010 at 12:45 PM
    xroller
    Ramon
    1 hp mod
    I have that part...
    I'm an xrunner.... I only come in 2wd. lol.... either way you have the same size diff as me 8.4"
  9. Dec 13, 2010 at 12:47 PM
    htx6002
    htx6002 [OP] Member
    houston texas
    taco prerunner
    ill pm u!!!
  10. Dec 13, 2010 at 1:16 PM
    htx6002
    htx6002 [OP] Member
    houston texas
    taco prerunner
    anybody else have any other websites where i can find part?
    thanks
  11. Dec 13, 2010 at 1:26 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Check for a local driveline shop. They are pretty common.
    Spicer makes the driveshafts for the 2nd gens, and any sprice dealer can most likely call them up and order just that part.
    Good luck
    Justin
  12. Jan 31, 2011 at 11:41 AM
    ibcallindux
    ibcallindux Member
    Drew
    Clemson SC
    99 taco single on 33's
    2.5" lift 33" BFG AT's
    I know this thread is aging but I have the same problem now. Hasn't disconnected yet but went to have the U-joint repaired and the mechanic told me the yoke was shot. Any more info on anyone that would have one for a 99 single cab 4wd? Also is it called the flange yoke that is on the axle side or something else?
  13. Nov 22, 2011 at 3:48 AM
    couldbriding
    couldbriding Well-Known Member
    Western Pennsylvania
    08 SR5 4x4 Access Cab
    Leer XL Truck Cap USA Spec DF-Toy Interface Leather Door Inserts WeatherTech floor mats Pop n Lock XM Satellite Radio with Pro.fit mount
    I thought I would revive an old thread. So I have been searching for this part for over a month now with no luck. My universal joint grenaded and took a part of the flange yoke with it. there are 2 part numbers I could find on it... Spicer 5001905 and 200607. This is the yoke that connects the rear driveshaft to the differential in my 4x4 access cab. I went to a local Spicer shop and they could not find it in their big book of parts. Does anyone know where I may be able to find this? I will even take one from the junk yard!
  14. Jan 4, 2012 at 7:39 AM
    fcetrentcad
    fcetrentcad New Member
    fred
    I am a cadillac dealer in eastern NC and recently needed a spicer 5001905 and had to buy 2 to get one and have the other one for sale.
    If interested call Freddie at 252-633-2213.
  15. Apr 30, 2013 at 11:01 AM
    cohrmundt
    cohrmundt Well-Known Member
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    4.88 nitro gears, Detroit rear, Projector headlights, Relentless Fab custom bumpers and sliders, 6" Pro Comp suspension, all pro leafs, 37x13.5x17 toyo open country tires, method racing wheels, Flowmaster exhaust w/cutout, DTLT headers, K&N CAI, URD MAF calibrator, grillcraft grill with 30" and 20" led bars behind, windshield mounted 50" led bar, Infinity 6x9 speakers, Custom box w/MTX 7500 10"sub, MTX 1200 watt amp, blue led gauge cluster and radio mod, URD short shifter, fiberwerx fenders
    had to bring this old thread back, cause now i too need this flange yoke. This part is so hard to find, does anyone have any ideas on where to buy one?
  16. Apr 30, 2013 at 2:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you call Freddie at 252-633-2213? Maybe he still has it.
  17. Apr 30, 2013 at 2:25 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    I had my u joint explode on the way to the river a couple weeks ago and it killed the flange it was a pain in the Ass to get the part because Toyota will only sell the entire drive shaft for 1k and even Spicer dealers can't get the part because it is exclusive to Toyota. I had a driveline shop in Havasu order me one. It was not spicer but was identical. I have about 2k miles on the new u joint yolk and no problems. And the yolk only cost $60 bets the sit out of a grand from Toyota
  18. May 17, 2013 at 9:48 PM
    cohrmundt
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    Alright found a company that sells this exact spicer flange yoke for 38 bucks shipped to the house and only took 2 days to get it... Hell of a deal for those needing this part... Just go to www.northerndrivetrain.com in the search bar type in 2-2-01904 and this is the flange yoke for the front end and the rear end of the rear driveshaft
  19. Feb 22, 2015 at 7:32 PM
    TerrorTaco808
    TerrorTaco808 KANAKA MAOLI
    Philip
    Hilo, Hawaii
    08' SSM DCSB SR5 4x4
    6" Fabtech suspention lift (Basic system),B110 5100 Billy's in the rear, 3" Body lift, 17x8.5 Fuel Trophy's wraped with 35x12.50 Kumho Road Ventures(KL71), custom BHLM retrofit heads with 6k morimoto D2S bulbs, Morimoto HID ballasts with ignighter, Opt7 3k LED Fogs, anytime fog light mod, Semi-Debadged, Dipped valance, badges, and emblem, custom 4 ft RGB LED lighted whip with custom mount, EZ down tailgate strut, 50" 5D LED light bar roof mounted via custom low profile mounts by MCM Fab & Design, custom cat back exhaust, muffler delete and replaced with a Flowmaster super44
    Opening up this thread again, looking for the same part, transfer case yoke flange got hammered from a u-joint going bad. Searched the above website but parts were flagged as obsolete, other sites are labeled no longer available, didn't hit up the junkyards yet but figure I try out my luck here. Any help would be much appreciated
  20. Feb 22, 2015 at 9:10 PM
    cohrmundt
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    I emailed the guy that found me this part the last time, will let you know what he says when I hear back from him
