Flappin mad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nick54, Dec 29, 2010.
  1. Dec 29, 2010 at 5:52 PM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    After installing my Duratracs I'm getting a slight rub from the front tires hitting the mud flaps. I know I can trim them but I would like to do it off the truck. Can anyone tell me how to remove the fasteners without damage so that I can reuse them if possible. If not, I'm sure I can nut and bolt them. Any advise is appreciated - Thanks
  2. Dec 29, 2010 at 6:06 PM
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    I just used a pocket knife to pop them out. Seems like there were a couple of screw fasteners too. Can't really remember for sure. I do know that I didn't have any trouble taking them off or putting them back on.
  3. Dec 29, 2010 at 6:09 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights
    Just pop them out with a flat head screw driver. Takes all of 30 seconds. I've taken my flaps off and put them back on a couple times and never had a problem with a fastener breaking.
  4. Dec 29, 2010 at 6:13 PM
    Tippett's TRD
    Tippett's TRD Well-Known Member
    Josh Tippett
    Lake Linganore, Maryland
    2010 Speedway Dbl Cab L/B 4x4
    6" Pro Comp Suspension Lift, LEER Cap, NFAB Nerf Bars, Avid Off-road Bar, K&N Intake, Weathertech Liners, 2011 Grille, BedRug, Westin Taillight Guards, Tinted Windows, RedLine Hood Struts, Mag Lite Mod, Stubbie Antenna...
    ^^Same as him.. small flathead does the trick
  5. Dec 29, 2010 at 7:38 PM
    Nick54
    Nick
    Mentor Ohio
    Thanks for the input, I will take a shot tomorrow.
  6. Dec 30, 2010 at 8:54 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    What they said. You put the center of the fastener up a little, then you can pull the fastener out. Plus there's the two screws (assuming they're the same as the '05). Just beware that as the truck ages, so will the plastic. At some point, a few years from now they will break if you try and remove them because the plastic will be brittle (mine were that way after 4 years).
