Flapping Tonneau at Highway Speed
Discussion in 'Tonneau Covers, Caps and Shells' started by Snyperx, Feb 10, 2009.
  1. Feb 10, 2009 at 7:07 AM
    Snyperx
    Snyperx [OP] Seniore Marcos
    I have a Access Limited Edition soft tonneau cover and noticed that it really seems to flap at highway speed. What have people done to solve this? Is it caused from air getting into the bed while driving? I thought about sealing all the edges with a urethane sealant or something similar. Any help is appreciated.
  2. Feb 10, 2009 at 7:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm not familiar with the Access - in how it attaches to the framing.
    I have an Advantage and it does the same thing. I don't worry about it at all. The vinyl tonneau material stretches in different temps. In the cold weather, it'll be tight while in the summer, it'll be loose.
    I used to own several of those snapped covers and they were a bitch to put on in the winter because the vinyl was so damn hard/shrunk. Those covers had a spring loaded end-frame that always kept the vinyl tight. My Advantage cover doesn't have snaps and is permanently attached to the framing and there's nothing to take-up the slack of the vinyl when its warmer out.
    The only thing I do is keep it clean and put vinyl protectant on it to prevent the vinyl from cracking, fading, etc.
  3. Feb 10, 2009 at 7:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...it'll flap a bit because of the air pressures and speeds over the bed. There should be a tensioner at the head of the bed that you can tighten the tonneau with-but the tighter you pull that the harder it is to close and the more the cover stretches.
    I use black silicone to seal the corners of the box usually but that's more for water than air.
  4. Feb 10, 2009 at 7:29 AM
    jmasterj
    jmasterj Samsonite...I was way off!
    07 TRD Off Road
    Have you tried adjusting the XT dials to make the tonneau tighter?
  5. Feb 10, 2009 at 8:03 AM
    stro1965
    stro1965 Well-Known Member
    Bellevue, NE
    09 Timberland Mica Tacoma 4x4
    Ditto, sounds like you just need to tighten it up a little bit. I have the Access Literider and it doesn't flap.
  6. Feb 10, 2009 at 8:08 AM
    Snyperx
    Yeah, I did tighten the cover a bit with the dials already. It still flaps. As a side note it seems to do it more on the drive side.
  7. Feb 10, 2009 at 9:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Did you tighten them evenly?? Count threads on each side to make sure they match...
  8. Feb 10, 2009 at 4:02 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    How do you like it? Just received mine today.
  9. Feb 11, 2009 at 8:53 AM
    Snyperx
    I didn't count the threads, but I measured the length of how much was showing on each side.
  10. Oct 1, 2009 at 9:34 AM
    Elliebarley1978
    Elliebarley1978 Well-Known Member
    canada
    weathertech floor liners, wet okole fronts, leer 100xq cap, trd exhaust
    did you ever find out why it was flapping? i was thinking of buying one but this flapping issue is changing my mind.
  11. Mar 26, 2017 at 7:54 PM
    bob87
    bob87 Well-Known Member
    2019 cav blue access cab SR5, 4x4 Tacoma 3.5L
    I am following this thread with interest since I just bought an Access Original roll up soft tonneau cover. It is not installed yet as I am waiting for milder temperature to work on it outside. My garage is full of gear and stuff.
  12. Sep 1, 2017 at 6:12 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Any updates on this? Flapping resolved?
