Flared wrenches
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARB1977, Jan 2, 2014.
  1. Feb 25, 2014 at 9:43 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
  2. Feb 25, 2014 at 9:50 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm new when it comes to dealing with brake lines.
    How do flared wrenches work better over the average wrench?
    A buddy and I were trying to get the bottom end loose and we were bending the mount. It would budge...
  3. Feb 25, 2014 at 12:23 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    a flare nut wrench will encapsulate the nut better. and will help with not stripping the nut. heres a pic, one side is normal the other side is a flare nut wrench.
  4. Feb 25, 2014 at 12:37 PM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Whatever you do, DO NOT INSTALL A COMPRESSION FITTING IN A BRAKE SYSTEM. There is a reason they are not used from factory, and are not DOT compliant. If you have to cut a line, install a flare nut on each, re-flare, and use a proper coupler made for brake lines.
  5. Feb 25, 2014 at 6:00 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    X2 never on brake lines, that's pretty much 1st grade. I was referring (as I stated) to a post about the fittings on the RACK AND PINION and its removal. That fellow seems to have deleted his post.
  6. Feb 26, 2014 at 5:33 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Yeah same deal, high pressure with major consequences, granted you will still have steering if that coupler leaks, but I would rather have something more positive than a compression fitting for my 1500 psi steering system.
  7. Feb 26, 2014 at 9:32 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    You can certainly have your preference, that's fine, on the other hand so can I.
    That fitting is not your common compression fitting. It is forged steel, specifically designed for use on high pressure carbon steel tube, has internal vibration dampers, positive locking self swaging sleeves and is rated for 4560 psi.
  8. Feb 26, 2014 at 10:05 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Correct. And as a mechanical engineer who specs components for hydraulic systems all the time, I would lose my job spec'ing a compression fitting like that for a high pressure fitting in a critical system. Something like that is meant for a repair, to be replaced correctly asap. ;)
    One's life is simply not worth using a compression fitting to me. If Toyota thought compression fittings were suitable for this application, the fitting at the rack would not be a flare fitting with tube nuts.
  9. Feb 26, 2014 at 7:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Unless maybe because compression fittings are a one-time-use item, meaning that the lines could not be removed for repair or replacement of the rack, front end components, etc....
