FLASHING AIRBAG LIGHT???
Discussion in '1st Gen. Tacomas (1995-2004)' started by igarrpan, Aug 22, 2011.
  1. Aug 22, 2011 at 9:05 PM
    igarrpan
    igarrpan [OP] Member
    Northern Utah
    99' Tacoma- Elite bumper
    Has anyone had a flashing airbag light go off in their truck? Any ideas on how to make it go away or fix it?
  2. Aug 22, 2011 at 9:06 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Take the dash apart and remove the led :D
  3. Aug 22, 2011 at 9:11 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Airbag computer failure or sensor failure.
    Edit try disconnect the battery and waiting 15 mins. That discharges the air bag computer caps. if that doesnt work then you have two points of failure. to look at.
  4. Aug 23, 2011 at 8:41 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    if you have a code checker, see what codes it's throwing. or take it to a dealer/mechanic to get that checked ASAP.
  5. Aug 26, 2011 at 6:54 PM
    White-Lightning
    White-Lightning Well-Known Member
    Amherst, Va
    02 Tacoma 4cyl
    this happened to me one time and i simply looked under my dash where the fuse box is and there were two wires that became disconnected and it so happened to be my airbag plug, so give it a look and see what you see.
  6. Aug 27, 2011 at 8:22 AM
    igarrpan
    Northern Utah
    I ended up taking it to the dealer and it turns out the sensor in my seatbelt went bad... I guess that can happen if its pulled out all the way and gets yanked on hard... or they can just go out.. ive got 196500 on the truck. Anyways, $250 for a new seatbelt.
  7. Aug 27, 2011 at 10:21 AM
    brannman
    brannman Well-Known Member
    Chesapeake, VA
    01 TRD
    funny this should come up. mine has been doing the same for a few weeks. avoided going to the stealership cuz that just means $$$. after this hurricane i;ll check the fuses and then disconnect the battery if all fuses are intact.
    i figured the worst that could happen was i'd get in an accident and my airbag wouldn't deploy...
  8. Aug 27, 2011 at 10:25 AM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    Honda has life time seat belt replacement. I was just talking to my friend that's a mechanic at Toyota. He wishes Toyota did the same.
  9. Sep 19, 2012 at 1:08 PM
    Tashier
    Tashier Well-Known Member
    Sean
    Beaverton, OR
    99 Tacoma V6 Limited
    Air Bar Suspension
    Now having same problem. Flashing SRS light. Probably a problem with my seatbelt tensioner.
