Flashing brake warning light under braking?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mike Drew, Oct 3, 2017.
  1. Oct 3, 2017 at 7:20 PM
    Mike Drew
    Mike Drew [OP] Member
    2003 Tacoma Pre-runner 2WD
    None
    Hi--my first post here.
    I've got a bone stock 2003 Tacoma with 140k miles on it. Recently the brake warning light has flashed briefly under moderate braking. My assumption was that the fluid level in the master cylinder was low and it was sloshing away from the sender, momentarily illuminating the light to indicate fluid loss.
    But the master is completely full.
    The parking brake handle is totally released. So far as I know, those are the only two inputs to the warning light circuit. So what am I missing?
    Thanks for any words of wisdom you can offer.....
  2. Oct 3, 2017 at 8:00 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    the sensor for the fluid level. Play with it/ unplug it/ use a turkey baster to pull out some fluid.....anything to recreate the problem.
  3. Oct 3, 2017 at 8:03 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sometimes the e-brake needs tightened ever so slightly. If you push on the handle it should go out. Theres numerous posts about this being a problem
    cruxofthebisquit likes this.
  4. Oct 3, 2017 at 9:16 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    There's a switch on the e-brake mechanism, lighting up the light when it is on. So maybe your e-brake is a little bit out of adjustment, making the light come on
  5. Oct 3, 2017 at 9:57 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    true. I forgot mine did the same. Hit the brakes hard and it pushes the lever forward a bit.
  6. Oct 4, 2017 at 12:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The spring at the Intermediate lever needs some lube once in awhile also .
    That spring pulls the emergency brake cable just enough to keep the handle retracted all the way.
    Another possible problem something else grounding back through that circuit
