Flashing dash lights. Weird noises.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lthompson, Jul 30, 2016.
  1. Jul 30, 2016 at 10:29 AM
    Lthompson
    Lthompson [OP] Well-Known Member
    Why does the Light shaped like a car with a key inside it always flash when my truck is sitting? It doesn't seem to stop. Seems like it will drain the battery if sitting too long. Locked or unlocked it doesnt matter. And the blue light under the dash flashes a bunch sometimes when locked. also a while back I went in the garage and my truck was making a weird noise close to the rear that sounded kinda like a really small compressor... what the heck was that? It had been sitting about a day.
  2. Jul 30, 2016 at 10:32 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The sound in the back is the fuel pump. It goes through a system self check. Its normal. The key light is the security system.
  3. Jul 30, 2016 at 10:36 AM
    Lthompson
    For instance, Truck is all locked up... Been sitting for 15-20 minutes. red key light is still flashing.. And the blue light under the dash is still flashing. how do I make it stop.. How does the security system work.. How is it turned on.. how is it turned off.. What does it do.. I don't have a manual, so don't point me there please haha.
  4. Jul 30, 2016 at 3:32 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Blue light under the dash? Guessing it's an after market alarm system? Find out for sure and work from there.
  5. Jul 30, 2016 at 6:11 PM
    moondeath
    Pa, Gardners
    The blue light, I dont know what that is. The light with the vehicle and key is the factory security. Its just letting you know its active. Its normal. Wont kill the battery. When you lock the truck it becomes active.
  6. Jul 30, 2016 at 6:54 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  7. Jul 30, 2016 at 6:56 PM
    moondeath
    Pa, Gardners
