Flashing Key/Car Light on Dash Next to Clock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USACM, Mar 19, 2016.
  1. Mar 19, 2016 at 5:44 PM
    USACM
    USACM [OP] Member
    Stephen
    Upstate New York
    2011 Tacoma TRD Sport DBL CAB LB
    TRD Cold Air Intake System LED Headlights and Fog Lights and All Interior/Exterior Lights Amber Center Console and Footwell LED Lighting Grill and Tailgate TRD Badges TRD Shift Knob TRD Antenna Hood Visor Window Visors Tinted Windows Extang Tonneau
    I'm new to the forum so hello to all. Can someone please tell me what pins in the 14 pin connector control the flashing key/car light in the dash next to the clock? 2011 Tacoma TRD Sport DBL CAB LB. Thanks!
  2. Mar 19, 2016 at 8:26 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Isn't that the light that signals if the ignition has an immobilizer? What do you want to do with the light?
  3. Mar 19, 2016 at 8:49 PM
    USACM
    USACM [OP] Member
    Stephen
    Upstate New York
    Yes, it is. It constantly flashes when the key is out of the ignition and stops when you insert the key. I wanted to use that circuit to run an additional flashing light. Just as a visual Deterrent. I figure that if most would be thieves (who know what they're doing)see the factory light, they're more likely to bypass the system and break in. If they think there's an aftermarket system installed , they may be more likely to just move on.
  4. Mar 20, 2016 at 5:18 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I would like to do the same thing, Extra light on the dash some place may make a POS think twice before doing something stupid. Good idea OP.
  5. Mar 20, 2016 at 5:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    Install a fake one that is switched to a constant hot and you can leave the factory immobilizer harness alone. Something like this.
    NeedmoreTaco likes this.
  6. Mar 20, 2016 at 6:59 AM
    mcnkl
    mcnkl Active Member
    calgary,alberta
    ^^ like said above leave factory immo harness alone.
    I've installed a couple varad led theft deterrents at the shop and there bright, easy install as well.
    3 wires to hook up constant 12volts, ignition and ground. When the key is in the off position the led flashes but as soon as it sees ignition turned on led turns off, no switch required.
    1buzzbait likes this.
  7. Mar 20, 2016 at 7:05 AM
    1buzzbait
    1buzzbait yer not gone like my honesty
    Murph
    murrilin
    98 yamaha grizzly
    no matter what you do, if they want it, it's gone, get a bigger dog or gun
  8. Mar 20, 2016 at 7:15 AM
    USACM
    USACM [OP] Member
    Stephen
    Upstate New York
    Thanks for the suggestions... That's what I'll do then.
