Flashing LED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Halena Molokai, Feb 10, 2017.
  1. Feb 10, 2017 at 6:29 PM
    Halena Molokai
    Halena Molokai [OP] Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Got the stock alarm on my TRD 4x4 OR DCSB MT6 and I want to install a flashing LED. Red wire to constant power - Black and Yellow to Alarm Systems Accessory Output. Does any one know where to tap into it and what color wire is the Alarm Acc Output. tis
  2. Feb 11, 2017 at 1:41 AM
    Halena Molokai
    Wow! no replys on this?
    Ok how can I hook up the 3 wire's without using the alarm so the light will go off when ignition is turned on.
    Red - +12v constant or battery +
    Yellow - +12v ignition ( grounded when the engine is OFF)
    Black - Metal chassis ground
    I would like to tap into wires on the drivers side. Can someone tell me which wires to tap the red and yellow wires to. Tks TW
  3. Feb 11, 2017 at 7:23 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If all you want is a fake flashing LED, why not get something like this. Then there is no need to tap into wires.
    https://www.amazon.com/RED-Flashing-Auto-Theft-Deterrent/dp/B00LCBIJYK
  4. Feb 11, 2017 at 8:03 AM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    How about a scanning LED light on the front of the truck like night rider? You can pair that with the club, go full 80s security system, and no one will mess with your truck
  5. Feb 11, 2017 at 8:06 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    Pretty sure mine has a flashing red light when it's locked from the factory.
  6. Feb 11, 2017 at 8:14 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Doesn't a light on the dash already flash when the factory alarm is armed?
    If you want your own flashing light, I'd go about it this way: Grab something like this then add a NC relay wired to pass power from +12VDC constant when the ACC is powered. You can use fuse taps to get constant from the open spot in the in-cab fuse block and ACC from the AUX NO 1 fuse.
  7. Feb 11, 2017 at 8:37 AM
    Halena Molokai
    I already have the Varad single flashing LED. Since the stock alarm does not come with one like other after market ones I wanted to mount one center of the windshield where the map light is. The idea is to see it when looking at the truck from the front. I know I have the stock light at the dash console but here in the 808 some of us roll that way. It's just a deterrent from a distance.
